How Do You Solve Equations with Square Roots and Quadratic Terms?
  • Thread starter Thread starter Stratosphere
The discussion centers around solving equations that involve square roots and quadratic terms, specifically focusing on the equation \(\sqrt{x-1}=x-7\) and similar radical equations.
  • Mixed
  • Participants explore the transformation of radical equations into quadratic forms and discuss methods for solving quadratic equations, including factoring and the quadratic formula. There are questions about the implications of squaring both sides of an equation and concerns about extraneous solutions.
Participants are actively engaging with the problem, with some providing guidance on how to manipulate the equations. There is a recognition of the need to check solutions against the original equations, and multiple interpretations of the problem are being explored.
Some participants express confusion regarding the nature of the equations, questioning whether they are dealing with radical or quadratic equations. There are also mentions of specific examples that introduce additional complexity, such as having square roots on both sides of an equation.
Stratosphere
A basic example is [tex]\sqrt{x-1}[/tex]=x-7
I end up with an x[tex]^{2}[/tex] and a normal x I don't know to to solve it.
Please show us your work. You say you have and x2. ok, you should have an x2 term, now show us exactly what you have and how you got it.
So that's a quadratic equation, isn't it? You can solve quadratic equations by factoring, completing the square, or using the quadratic formula.
I thought this was a radical equation? Not a quadric one. If this is a quadric one I don't have to worry abought that yet then.
How do you solve somthing with a root on both side then? Like [tex]\sqrt{3x+2}[/tex] + [tex]\sqrt{2x}[/tex]= 35, I keep getting an answer that's too high.
Turn it into
[tex]\sqrt{3x+2} = 35 - \sqrt{2x}[/tex]
square both sides
[tex]3x+2 = 35^2 + 2x - 70 \sqrt{2x}[/tex]
and now you only have one square root
Stratosphere, your first example, [tex]\sqrt{x-1}[/tex] = x - 7, should give you no complications when you square both sides. It WILL give you a quadratic equation. Either you can (after suitable algebraic steps) factor and solve, or you can complete the square/use solution to quadratic equation to solve.
were does the -70 come from?
[tex](35-\sqrt{2x})^2[/tex]
Expand it out.
Don't forget, when you square the radical, you can end up finding solutions for x that do not work. You have to go through and check these solutions with your original equation to make sure that each value works.
Oh and how do you know what is a,b and c when using the quadratic formula?
The general form of a quadratic equation is [tex]ax^{2} + bx + c = 0[/tex]. Hopefully that answers your question. ;)
01
  • · Replies 20 ·
