What is the Relationship Between Fermi Velocity and Fermi Energy?
The discussion revolves around the relationship between Fermi velocity and Fermi energy, exploring their definitions, measurements, and implications in the context of electron behavior in conductors. It touches on theoretical aspects, including the dispersion relation and the effective mass theorem.
  • One participant suggests that Fermi velocity is the velocity of electron-wave in a conductor and questions its relation to Fermi energy.
  • Another participant explains that electrons' energies should be measured relative to the Fermi surface, with Fermi velocity acting as a constant of proportionality in this context.
  • A different viewpoint states that Fermi velocity is the velocity an electron would have if it possesses Fermi energy, noting that not all electrons move at this velocity.
  • It is mentioned that in certain conditions, such as low temperatures and small biases, Fermi velocity can be used as a good approximation for electron velocity in a degenerate conductor.
  • Participants discuss the effective mass and its role in relating momentum to velocity, emphasizing that the semi-classical interpretation of velocity applies under this theorem.
  • A mathematical expression for the dispersion relation is provided, linking energy, momentum, and effective mass to derive Fermi velocity.
Participants express varying interpretations of Fermi velocity and its relation to Fermi energy, with some clarifying points while others present differing views. The discussion does not reach a consensus on the definitions or implications of these concepts.
Some participants highlight that the selection of a zero energy reference point is arbitrary, and the discussion includes assumptions about temperature and system conditions that may affect the applicability of Fermi velocity as an approximation.
carbon9
Hi,
Is this right: Fermi velocity is the velocity of electron-wave in a conductor. Why is it called Fermi velocity, i.e. what is its relation with Fermi energy, etc..
Thanks a lot.
Cheers
Electrons' energies should be measured relative to the Fermi surface (or the chemical potential at non-zero temperatures). Similarly, the momenta should be measured relative to the Fermi surface. To first order, the constant of proportionality is the Fermi velocity. For non-interacting Fermi gas, this can be directly related to the dispersion relation for a single particle. For an interacting Fermi liquid, it's usually best to simply measure this.
Notice that Fermi velocity is directly related to the density of states (exercise to work out how).
Thanks.
Electrons energies can be measured relative to whatever energy you'd like. The selection of a zero energy is arbitrary.
Fermi velocity is the velocity with which an electron would travel, if the electron has Fermi energy.
No, not all the electrons are moving with the Fermi velocity, say, in a solid. But since the current flow occurs around the electrochemical potential (interchangeable with Fermi Energy here) most of the electrons have energies at around the Fermi energy ( a few kTs above and below).
If the temperatures are small and the device is in the linear regime (small bias) and the channel is a degenerate conductor ( where Ef is at least a few kTs above the conduction band) - we can use fermi velocity as the velocity of electrons to a very good approximation.
Indeed, if you use the renormalised/effective mass to relate momentum to velocity
Yes, that's right. Thanks for correcting that. "Velocity" in the semi-classical sense (the way it is used for Fermi velocity) makes sense only under the effective mass theorem.
Say your dispersion relation looks like:
[tex]E = \hbar^2 k^2/ 2m^* + U_0(x)[/tex] where U(x) = 0 arbitrarily
and since
[tex]\frac{d\overline{x}}{dt} = \frac{1}{\hbar}\overline{\nabla}_k E[/tex] (Hamiltonian Mechanics -- reminder of our semi-classical approach)
and if you take the derivative of E (and plug E=Ef and k=kf) with respect to k and divide by hbar to get the velocity you obtain:
[tex]v_f = \frac{\hbar k_f}{m^*}= \frac{p}{m^*}[/tex]
where m*'s denote the "effective mass" for the bottom of the conduction band (parabolic band approximation)
as genneth properly corrected.
Thanks.
10K
