New Reply
Charge and current density
Share Thread Thread Tools
Mar24-09, 11:58 PM   #1
Can we make a mathematical (equation) relationship between Current Density and Charge Q.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar25-09, 04:16 AM   #2
hmm... it seems to me that without any additional information it is only possible to connect dQ/dt with j.
Mar25-09, 04:37 AM   #3
I am trying to find Q using a relationship in which there is no area A.
Knows are
electric potential U
Total flux density D
Total Field Intensity E
Current Density
Inductance.
Mar25-09, 04:47 AM   #4
There is a relationship between charge density and current density; the charge continuity equation.
Mar25-09, 05:25 AM   #5
Oscar6330, could you please be more specific? What is the physical system you are trying to describe? For instance, A is area of what? U is electric potential between what points? and so forth...
Mar25-09, 05:34 AM   #6
In a relativistic theory charge density and spatial current density form a four vector current density j_\mu. In the non relativistic limit they are related by the continuity equation.
Mar25-09, 05:50 AM   #7
I am trying to find out the capacitance of a system. Now C=Q/V. I am using a Simulation software. The only output parameters available are
Current Density J
Inductance.
I am really stuck with it and need help as I am not a Physics guy. Pl tell me some equation
Mar25-09, 06:32 AM   #8
I don't quite understand...
What is total field intensity? at what point? and what is flux density?
If field intensity E is known on the surface S of the conductor you can integrate it over the surface to get total charge Q (Gauss's law)
[tex] $ Q = \varepsilon_0 \int_{S} E_n dA$ [/tex].
Capacitance C is then C = Q/U.
I have a feeling that flux density is just [tex] $ \textbf{D} = \varepsilon_0 \textbf{E}$ [/tex] so [tex] $ Q = \int_{S} D_n dA$ [/tex]
But I'm not sure...
May be capacitance of your system has already been calculated by someone? =)
Mar25-09, 06:42 AM   #9
LOL....well since this is not an assignment, so no one has solved it. So the problem still remains unsolved
Mar25-09, 04:35 PM   #10
Quote by naturale View Post
It's a relativistic equation as well. The charge continuity equation is Lorentz invariant, and more, is covariant without connections on a curved spacetime.
Mar25-09, 05:32 PM   #11
Ok. what i mean is that in the non relativistic limit the charge density is give by j_0 \propto |\phi^2| and it can be associate to a quantum probability but in the relativistic limit the charge density it is not positively defined and thus it is not consistent with a probability interpretation. J_0 \propto \phi* (d_t \phi) - (d_t \phi*) \phi.
Mar26-09, 04:48 AM   #12
I don't know what a relativistic limit is. Usually you want to keep things at v<c. That way it all works out, is that Maxwell's equations are true, relativistic equations. The charge continuity equation is a direct mathematical consequence, and therefore relativistically invariant itself.
Mar26-09, 04:52 AM   #13
To be honest, I cannot understand where its going. Can you guys please redirect to my topic
Mar26-09, 05:02 AM   #14
you are right. the relativistic interpretation of the charge density as a probability can be the object of another topic.
Mar26-09, 05:21 AM   #15
Quote by Oscar6330 View Post
Sure, Oscar. Without a little more to go on, we don't know what to go on. You need to explain your system.
Mar26-09, 05:25 AM   #16
That sounds interesting. Why don't you start a thread?
Mar26-09, 05:37 AM   #17
Well it is very simple. I want to compute capacitance C. Now from my simulation software i can only get the following outputs, which are
electric potential V
Total flux density B
Total Field Intensity H
Current Density J
Inductance.
So I just want an equation, which has these variables only to calculate Capacitance (and some constants)
New Reply
Thread Tools
Similar Threads for: Charge and current density
Thread Forum Replies
Total Flux Density VS Total Field Intensity VS Current Density Classical Physics 0
current density constant in time implies charge density linear in time? Classical Physics 1
Charge velocity and current density Introductory Physics Homework 4
Finding diameter of a wire based on the current and current density. Introductory Physics Homework 1
induced charge density by non-uniform dipole density in dielectric?! Classical Physics 1
