Solving Doublet Slit Problem: Find Wavelength of Laser 2
  • Thread starter Thread starter noellcm
    Slit
The discussion focuses on determining the wavelength of a second laser (lambda_2) that aligns its second maximum with the fourth minimum of a first laser, which has a wavelength of d/8. The slit separation is specified as 0.350 mm. The relevant equations for interference patterns are dsin(theta) = m(lambda1) for maxima and dsin(theta) = (m + 0.5)(lambda2) for minima. The user attempts to solve the problem by equating the sine values derived from these equations but encounters difficulties in obtaining the correct wavelength.
  • Understanding of interference patterns in wave physics
  • Familiarity with the double slit experiment
  • Knowledge of the equations for maxima and minima in interference
  • Ability to manipulate algebraic equations
  • Review the derivation of interference equations for double slits
  • Study the concept of maxima and minima in wave interference
  • Practice solving problems involving wavelength calculations in interference scenarios
  • Explore the impact of varying slit separation on interference patterns
Students studying wave physics, particularly those focusing on optics and interference phenomena, as well as educators looking for examples of practical applications of wave equations.
noellcm
A laser with wavelength d/8 is shining light on a double slit with slit separation 0.350 mm. This results in an interference pattern on a screen a distance L away from the slits. We wish to shine a second laser, with a different wavelength, through the same slits.
What is the wavelength lambda_2 of the second laser that would place its second maximum at the same location as the fourth minimum of the first laser, if d = 0.350 mm?
location of interference maxima: dsin(theta) = m(lambda1)
location of interference minima: dsin(theta) = (m+.5)(lambda2)
i know that sin(theta) has to be the same for both of them, so i set these equations equal to sin(theta):
sin(theta) = (m*lambda1)/d
sin(theta) = ((m +.5 )*lambda2)/d
therefore:
(m*lambda1)/d = ((m +.5 )*lambda2)/d
d is given in the problem, so you know d for both sides. you also know that d/8 equals lambda one, so that can be solved. i have tried 2=m for lambda one because it is the second maxima and 3.5=m for lambda two (mastering physics told me to remember that the first minima is zero, not 1). i keep on getting the wrong answer though! please help!
So the equation should be
2/d*d/x = 3.5/d*d/8 .Solve for x, and then find the wavelength.
