Find equation of a Hyperbola that passes through two ordered pairs
  • Thread starter Thread starter synergix
    Hyperbola
The problem involves finding the equation of a hyperbola that passes through the points (-3,-2) and (4, sqrt(5)). The subject area is conic sections, specifically hyperbolas.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting up equations based on the standard forms of hyperbolas and substituting values from the given points. There is a focus on whether the assumptions about the hyperbola's orientation and center are valid.
Some participants have provided insights into the nature of hyperbolas and the implications of the assumptions made. There is acknowledgment of mistakes in earlier attempts, and one participant reports successfully resolving their issues after re-evaluating their approach.
There is mention of the infinite possibilities for hyperbolas passing through two points, and participants question the assumptions regarding the axes of symmetry and the center of the hyperbola.
synergix
Find an equation of the hyperbola that passes through the points (-3,-2) and (4, sqrt(5))
x^2/a^2 -y^2/b^2=1 or y^2/a^2 - x^2/b^2 = 1
To solve this problem I first started by setting up two equations containing the two ordered pairs. Then I solved for b for (1) and then substituted that into (2).
I used the standard form X^2/a^2 - y^2/b^2 = 1 for both
so..
(1) 9/a^2 - 4/b^2 = 1 and (2) 16/a^2 - 5/b^2 = 1
and...
I didn't get answers that checked.
I am wondering if I am even allowed to do that substitution I don't know if that is correct or not so what I am trying to determine is whether I am approaching this problem incorrectly or if my approach is sound but a mistake was made somewhere in my calculations?
First, just as there are an infinite number of circles that pass through two given points, so there are an infinite number of hyperbolas that pass through two given points. You are also assuming that the axes of symmetry are the x and y axes and that the center of the hyperbola is the origin though you do not give those as conditions.
Certainly, assuming that, the equation can be written as [itex]x^2/a^2- y^2/b^2= 1[/itex] or [itex]y^2/b^2- x^2/a^2= 1[/itex]. Trying the first, yes, the fact that the hyperbola goes through (-3, -2) gives [itex]9/a^2- 4/b^2= 1[/itex] and the fact that it goes through [itex](4,\sqrt{5})[/itex] gives [itex]16/a^2- 5/b^2= 1[/itex].
But it is impossible to say what you are doing wrong if you don't show what you did. HOW did you solve those equations and what result did you get? If you did not get a correct result, did you then try [itex]y^2/b^2- x^2/a^2= 1[/itex]?
Ok I made a mistake... I have tried again using Y^2/a^2-x^2/b^2=1
so I am solving the first equation for a
To eliminate the fractions I times both sides by a squared times b squared
(4/a^2-9/b^2=1)a^2b^2
4b^2-9a^2-a^2b^2=0
now I am stuck :( BTW my first attempt was incorrect(obviously) but I only got passed this point because I incorrectly manipulated the equations. I am not sure how to isolate the "a" variable here I will try to figure it out on my own in the meantime but if you could help that would be great.
Alright I managed it. I started this problem late last night(lame excuse) and I made a mistake when I was rearranging the equations but anyways I have solved it now and my answers checked thx!
  • · Replies 29 ·
  • · Replies 26 ·
