Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Biology
Reply
image Body wavelength Share It Thread Tools Search this Thread image
Old Mar29-09, 06:37 AM                  #1
Albert George
Albert George is Offline:
Body wavelength
Hi
We have talked in school about waves and I heard that our bodies have a wave length. What does it mean? I know it's very little.
I do not mean our brain but our entire body. Any good explanation would be appreciated.
Old Mar29-09, 08:05 AM                  #2
tiny-tim
tiny-tim's Avatar
Homework Helper 2008
tiny-tim is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Smile Welcome to PF!
Hi Albert George! Welcome to PF!
Yes, technically anything has a wave function, and has "wave behaviour" as well as "particle behaviour" … but for a human body the "wave behaviour" is soooo little that it has no noticeable effect whatever.
I think that the largest object for which any effect has ever been noticed is a C60 atom …
chuck C60 atoms through a double-slit, and you get the same "wave behaviour" effects as for light or electrons
Old Mar29-09, 08:09 AM                  #3
Borek
Borek's Avatar
Best Humor 2008
Borek is Offline:
Recognitions:
Re: Welcome to PF!
Originally Posted by tiny-tim View Post
C60 atom …
You call it an atom? I call it a molecule
Old Mar29-09, 08:14 AM                  #4
tiny-tim
tiny-tim's Avatar
Recognitions:
Red face oops!
oops!
Old Mar29-09, 08:48 AM                  #5
Albert George
Re: Body wavelength
Okay, but what does it mean that we humans have a wave function? What is causing it and is it always the same (a constant)? Is it on the electromagnetic spectrum or where can you place it?
Old Mar30-09, 10:45 AM                  #6
alxm
alxm is Offline:
Re: Body wavelength
It doesn't really mean as much as it seems to imply. Everything has a wavelength/wave function according to quantum physics. It means that things exhibit wave-like behavior under certain circumstances. But for a big, macroscopic object, the wavelength is too short for this to be measurable.
As they said, the biggest object they've been able to measure 'wave-like' behavior for is C60 - 60 atoms.
That's an object that weighs about as little in comparison to you, as you do in comparison to Jupiter.
The wavelength is h (Planck's constant) divided by p, the momentum of the object. As for why.. that's a fairly open question in physics.
No, because although things have wave-like behavior they're not necessarily electromagnetic waves.
Old Mar30-09, 06:43 PM                  #7
Andy Resnick
Andy Resnick is Offline:
Recognitions:
Re: Body wavelength
Hi
In general, if people are talking about wavelengths of the human body, they usually completely lack any real science. Especially if the subject of 'resonant behavior' or resonance, or something like that in connection with health and disease is also mentioned.
Old Mar30-09, 06:48 PM                  #8
mgb_phys
Physics Guru 2008
mgb_phys is Offline:
Recognitions:
Re: Body wavelength
You might also be thinking of the wavelength of infrared light our bodies emit because of our temperature - that's around 10um.
Old Mar30-09, 08:53 PM                  #9
JorgeLobo
JorgeLobo is Offline:
Re: Body wavelength
It's pure BS - humans have no "wave function."
Old Mar30-09, 08:58 PM                  #10
mgb_phys
Physics Guru 2008
Recognitions:
Re: Body wavelength
Has someone told Erwin Schrödinger ?
Old Mar31-09, 03:04 AM                  #11
Borek
Borek's Avatar
Best Humor 2008
Borek is Offline:
Recognitions:
Re: Body wavelength
Originally Posted by jorgelobo View Post
it's pure bs - humans have no "wave function."
What about HΨ=EΨ?
Old Apr1-09, 03:11 AM                  #12
Eidos
Eidos is Offline:
Re: Body wavelength
Human beings are also a 'perfect' antenna for some frequencies of electromagnetic radiation.
Now, everything that is conductive can act as an antenna, but it 'recieves' frequencies better than others. Basically if we were a thin piece of wire that is 1.5 m tall, 100Mhz is the frequency which we could pick up the best.
Say the average human is 1.5m tall. Now the 'perfect' antenna size, LaTeX Code: x is half a wavelength of the frequency you are using, LaTeX Code: x=\\frac{\\lambda}{2} .
This implies that the wavelength we are looking for is LaTeX Code: \\lambda=2\\;x=2(1.5)=3\\;m . The frequency that this wavelength corresponds to is,
LaTeX Code: f_{\\mathrm{MHz}} \\approx \\frac{300}{\\lambda}
or about 100Mhz*
*Note: this is assuming some special geometry (which we don't possess) and that we are purely conductive (which we aren't).
Old Apr2-09, 02:55 PM                  #13
Andy Resnick
Recognitions:
Re: Body wavelength
or about 100Mhz*
This is what I meant by not having a sound basis in science.
Old Apr2-09, 05:37 PM                  #14
Eidos
Eidos is Offline:
Re: Body wavelength
How is that not a sound basis in science? Your body acting as an antenna is an observable, measurable, repeatable fact. Granted my order of magnitude calculation is not 100% accurate since I was assuming a dipole geometry.
If I am in the wrong then we need a volunteer to go stand within a couple of meters to a high power HF transmitter to show that the human body cannot act as an antenna. :P
I was using reciprocity when I used the half-wavelength calculation. Also I had that LaTeX Code: c\\approx 300\\times10^8 m/s which is again a rough approximation.
Old Apr2-09, 07:39 PM                  #15
alxm
alxm is Offline:
Re: Body wavelength
Eidos, so you're saying:
But by the given rationale, you could say the same about any elongated conductor.
So the only thing you're actually saying about humans is that we're significantly taller than we are wide, and that we conduct electricity. Which is news to no-one, really.
Old Apr2-09, 08:20 PM                  #16
Eidos
Eidos is Offline:
Re: Body wavelength
The same is true for any elongated conductor ;)
Im convinced this thread was concerning body-wavelength. The antenna interpretation is here simply for the sake of offering an alternative to the other proffered explanation.
Enjoy
image image
Reply
Thread Tools
Similar Threads for: Body wavelength
Thread Thread Starter Forum Replies Last Post
wavelength yellowgold Quantum Physics 1 Nov5-08 12:39 AM
[SOLVED] [Multiple Choice] ...wavelength of an object. de Broglie wavelength daNAV1GATOR Introductory Physics 10 May1-08 02:59 PM
Shortest Non-Ionizing Wavelength for human body at any intensity/duration? Radium General Physics 4 Jan2-07 06:00 AM
Wavelength FateEternal Advanced Physics 2 Jan16-06 03:12 AM
What exactly is a wavelength? syano General Physics 9 Oct2-03 11:43 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
