Electron shot between plates (electric field)
The problem involves an electron moving between two charged plates in a uniform electric field. The scenario includes determining whether the electron will strike one of the plates and, if so, where it will do so, given its initial velocity and angle of projection.
  • Participants discuss the relationship between electric fields and forces acting on charged particles, questioning the appropriate equations to use. There is an exploration of how to break down the initial velocity into components and the implications of projectile motion in the context of electric fields.
Some participants have provided guidance on the relationship between force, electric field, and charge, while others have confirmed the need to consider both horizontal and vertical components of motion. The discussion appears to be progressing with participants gaining clarity on the concepts involved.
There is a mention of confusion regarding the initial conditions and the lack of provided equations, which may influence the participants' approaches to the problem.
miroku2192
I've been staring at this last problem for a while now...but i really don't get it. So if someone could explain to me how to do this, that'd be great. Thanks:
In Fig. 22-64, a uniform upward electric field E of magnitude 2.00 x 10^3 N/C has been set up between two horizontal plates by charging the lower plate positively and the upper plate negatively. The plates have length L = 10.0 cm and separation d - 2.00 cm. An electron is then shot between the plates from the left edge of the lower plate. The initial velocity of V(sub zero) of the electron makes an angle theta =45.0 degrees with the lower plate and has a magnitude of 6.00 x 10^6 m/s.
(a) will the electron strike one of the plates? (b) If so, which plate and how far horizontally from the left edge will the electron strike?
I'm really confused on this...so if someone could help that'd be great. I was never really good at physics.
Relevant equations? There were none provided..?
Can someone just point me in the right direction first? I'm a bit confused on how I'm supposed to go about even TACKLING the problem. Would i use the E= kQ/r^2 ? Since it's only one electron being acted on by the electric field? So it's like a point electric field thing?
No, that's the field produced by a point charge. You already know the field. You must find the force that the given field exerts on the electron. (What's the relationship between F, E, and q?)
Ohh...i see, so it's like a mix of electricity + projectile motions right? Because... F= Eq, and E is given, and q i know because it's the same for both protons + electrons right? something like -1.6 x 10^-19? Anyway, after i find the force in Newtons, i can just set it up as F = mass x acceleration, figure out acceleration and use projectile motions stuff right? I'm a bit shakey on projectile motions stuff though...when it says "a magnitude of 6.00 x 10^6 m/s.", does that mean after i find out acceleration, the initial velocity value i use is 6.00 x 10^6 m/s ?
Exactly right.
Yes, but realize that the initial velocity is at an angle, so you need to find horizontal and vertical components. Only the vertical component of motion is accelerated--just like with regular projectile motion.
Doc Al said:
Exactly right.
Oh right...i have to split up the x components and y components...Thanks so much, i think i get this question now. I really appreciate ALL your help!
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 26 ·
