How Do You Simplify Trigonometric Expressions Using Identities?
  • Thread starter Thread starter asdfsystema
    Trigonometry
The problem involves simplifying a trigonometric expression, specifically sin(x)/cot^2(x) - sin(x)/cos^2(x). The subject area is trigonometry, focusing on the use of identities for simplification.
  • Participants discuss converting cot^2(x) into terms of sin(x) and cos(x) and emphasize the importance of using trigonometric identities. There are attempts to rewrite the expression and questions about where to apply the identities effectively.
The discussion is active, with participants offering hints and guidance on how to approach the simplification. There is recognition of the need to combine terms and apply identities, but no consensus on the final steps or outcome has been reached.
Participants express uncertainty about the application of trigonometric identities and the simplification process. There is an emphasis on keeping the expressions in terms of sin(x) and cos(x) without converting to secant or tangent forms.
asdfsystema
Trigonometry Basic (URGENT) please help !
SIMPLIFY:
Trigonometric identities I think
I got sin(x)cot^-2(x) - sin(x) sec^2(x) ...
but the book says the answer is -sin(x).
Any starting points please? Thanks
First try changing the cot^2(x) expression into an expression in terms of sin(x) and cos(x), and leave everything in terms of sin(x) and cos(x), i.e. don't change the cosine expression in the right term into a secant expression.
As you've suspected, you will need to use trigonometric identities to aid in your simplification.
Hint: You should know the trigonometric identity tan(x) = sin(x)/cos(x). Try to take it from there.
After you've done that, try simplifying the entire expression into one fraction, still in terms of just sin(x) and cos(x).
I'll tell you that you will need to know at least one more trigonometric identity after you've gotten it simplified to a single fraction to complete the problem.
I'm not sure where to apply the trig identity.
I got sin(x)/ (cos(x)/sin(x))^2 - sin(x)/ cos(x)*cos(x)
Where does the identity come into play?
Thanks for the quick response
Ok, you applied the first trig identity cot(x) = cos(x) / sin(x) correctly. You need to clean this expression up a bit before you will be able to apply another identity. Combine the powers of sine and cosine in both terms, and see what the denominators will become. Remember if you are adding or subtracting two fractions with the same denominator, you may combine them into one fraction with that same denominator.
Hints: In any expression, (a/b) / (c/d) = (a/b) * (d/c)
Also, (a/c) + (b/c) = (a+b)/c
With trig expressions, they work the same as multiplying other expressions with identical bases, so for example
sin^4(x) * sin(x) = sin^5(x)
  • · Replies 16 ·
