Calculate Radius & Period of Revolution of Doubly Charged He Atom
The discussion focuses on calculating the radius of curvature and the period of revolution for a doubly charged helium atom with a mass of 6.6 × 10-27 kg, accelerated by a voltage of 2800 V in a 0.370-T magnetic field. The key equations used include F=qvB for force, centripetal acceleration as v2/r, and the period of revolution P=1/f. The charge of the doubly charged helium atom is established as +2e, indicating it has twice the charge of an electron.
  • Understanding of classical mechanics, specifically Newton's laws of motion.
  • Familiarity with electromagnetic principles, particularly Lorentz force.
  • Knowledge of energy conservation in physics.
  • Basic understanding of atomic structure and charge quantization.
  • Calculate the initial velocity of the doubly charged helium atom using energy conservation principles.
  • Explore the derivation of the radius of curvature formula r = mv/qB in detail.
  • Investigate the relationship between voltage and kinetic energy for charged particles.
  • Learn about the applications of mass spectrometry in analyzing charged particles.
Students studying physics, particularly those focusing on electromagnetism and particle dynamics, as well as educators and professionals involved in mass spectrometry and atomic physics.
MadMustang129
A doubly charged helium atom whose mass is 6.6 \times 10^{ - 27} {\rm{kg}} is accelerated by a voltage of 2800 V.
What will be its radius of curvature if it moves in a plane perpendicular to a uniform 0.370 -T field?
What is its period of revolution?
F=qvB
centripetal acceleration = (v^2)/r
P= 1/f
I know that F=ma, and a= (v^2)/r, and so r will = mv/qB.
My principle question is how can I find out the particle's initial velocity in the magnetic field based on the voltage that accelerates the atom? Also, what is the charge of a "doubly charged" He atom and how do you know? I understand the magnetism principles behind it but am having difficulty figuring out the speed at which the particle enters the mass spectrometer. Thank you... I appreciate the help!
Hi MadMustang129,
F=qvB
P= 1/f
Try applying conservation of energy to the motion before it reaches the magnetic field. What speed does that give?
Doubly charged means that the magnitude of its charge is (+2 e), so that it is twice the magnitude of an electron.
