Interference of Light waves HELP
The problem involves the interference of light waves reflected from a thin oil film on a glass plate, with specific wavelengths noted for constructive and destructive interference. The subject area is optics, particularly focusing on wave interference and the properties of thin films.
  • Participants discuss calculating the thickness of the oil film using interference conditions for both constructive and destructive interference. There are attempts to derive relationships between the wavelengths and the order of interference.
Some participants have provided hints regarding the phase differences required for constructive and destructive interference. There is an ongoing exploration of the equations involved, with one participant expressing uncertainty about their approach and seeking alternative methods.
Participants are navigating the complexities of phase differences and integer values for interference orders, with some noting the potential for multiple interpretations of the equations used.
yoshima
I've been trying to get the anwser to this question for awhile. Any help is appreciated. :confused:
1. A glass plate (n=1.61) is covered with a thin, uniform layer of oil (n=1.24). A light beam of variable wavelength from air is incident normally on the oil surface. Observation of the reflected beam shows destructive interference at 549 nm and constructive interference at 727 nm. From this information, calculate the thickness of the oil film.
thanks
find the phase difference
Show what you've tried and where you are stuck.
Here's a hint to get you started: Light will reflect off the surface of the oil and the surface of the glass. These two reflections will interfere. What phase difference must they have to interfere constructively? destructively? How does the phase difference depend on the thickness of the oil?
the solution that i though would be right
they way I've bee doing it is by using the formula for both destructive and constructive interference.
Constructive inter. --> 2nt=m*(lambda)c
destructive inter. --> 2nt=(m+1/2)*(lambda)d
Because the thickness of the film is the same --> 2nt = 2nt
:. (m+1/2)/(m) = (lambda)c/(lambda)d = 727/549
and from here solve for mc and sub that into the constructive formula 2nt=m*(lambda)c and you get the thickness.. but the anwser is not right.
Is there another way of solving this problem or am i solving the wrong way.
In your second equation, what you have as "m + 1/2" could also be m + 3/2, m + 5/2, etc. You need to find the value that makes m an integer. Trial and error!
