Reps of lorentz group and pauli and gamma matrices
The discussion centers around the transformation properties of gamma matrices and Pauli matrices under Lorentz transformations, particularly in the context of spinors in quantum field theory. Participants explore the implications of covariance in the Dirac equation and the relationship between Dirac and Weyl spinors.
  • Some participants assert that gamma matrices are constants and do not transform, while others challenge this view by discussing the implications of covariance and the transformation of spinors.
  • One participant expresses confusion about how to write Lorentz transformations for spinors and how Pauli matrices transform in this context.
  • Another participant suggests that the transformation properties of Weyl fields are detailed in a specific quantum field theory textbook.
  • Concerns are raised about inconsistencies in the application of transformations, particularly regarding the use of inverse transformations.
  • One participant proposes calculating the 4x4 spin-matrices in the Weyl basis to clarify how 2-component Weyl spinors transform.
  • Another participant mentions wanting to perform super Poincaré transformations and inverting those transformations, indicating a broader interest in the topic.
Participants generally disagree on the transformation properties of gamma matrices and Pauli matrices, with no consensus reached on the correct interpretation of their behavior under Lorentz transformations.
There are mentions of potential mix-ups in the application of transformations, indicating that some participants may have differing conventions or interpretations that affect their reasoning.
This discussion may be useful for those studying quantum field theory, particularly in understanding the transformation properties of spinors and the implications for Lorentz invariance.
bartadam
I'm very confused
By performing a lorentz transformation on a spinor [tex]\psi\rightarrow S(\Lambda)\psi(\Lambda x)[/tex] and imposing covariance on the Dirac equation [tex]i\gamma^{\mu}\partial_{\mu}\psi=0[/tex] we deduce that the gamma matrices transform as
[tex]S(\Lambda)\gamma^{\mu} S^{-1}(\Lambda)=\Lambda^{\mu}_{\nu}\gamma^{\nu}[/tex]
I understand that.
Now the Gamma matrices can be given by
[tex]\gamma^{\mu}=\left[ \begin{array}{cccc} 0&\sigma^{\mu}\\ \bar{\sigma}^{\mu} & 0\end{array} \right][/tex]
with [tex]\sigma^{\mu}=(1,\sigma^1,\sigma^2,\sigma^3)[/tex] and [tex]\bar{\sigma}^{\mu}=(-1,\sigma^1,\sigma^2,\sigma^3)[/tex]
and the dirac equation is reducible into the weyl equations.
[tex]i\sigma^{\mu}\partial_{\mu}\psi_L=0[/tex] and [tex]i\bar{\sigma}^{\mu}\partial_{\mu}\psi_R=0[/tex]
What is the way to write the lorentz transformations in this case, and how to the pauli matrices transform.
The gamma matrices are constants! They do not transform. Neither do the Pauli matrices.
It is the spinor (either Dirac or Weyl) that transforms. Try going over it again, carefully.
Then now I really do not understand. In order to maintain covariance the following expression is true.
[tex]S_{-1}(\Lambda)\gamma^{\mu} S(\Lambda)=\Lambda^{\mu}_{\nu}\gamma^{\nu}[/tex]
if we write a lorentz transformation on a spinor as [tex]\psi'(x')=S(\Lambda)\psi(x)=S(\Lambda)\psi(\Lambda_{-1}x')[/tex]
then say [tex]i\gamma^{\mu}\partial_{\mu}\psi(x)=0[/tex] then
[tex]i\gamma_{\mu}\Lambda^{\rho}_{\mu}\partial_{\rho}'\psi(\lambda_{-1}x)=0[/tex]
so [tex]i\gamma_{\mu}\Lambda^{\rho}_{\mu}\partial_{\rho}'S^{-1}\psi(x')=0[/tex]
Then multiply on the left with S
[tex]iS\gamma^{\mu}S_{-1}\Lambda^{\rho}_{\mu}\partial_{\rho}'\phi'(x')[/tex]
and then impose covariance so the form of the equation is unaltered in the transformed frame so that [tex]S\gamma^{\mu}S_{-1}\Lambda^{\rho}_{\mu}=\gamma^{\rho}[/tex]
That's in every textbook and my lecture notes lol. What happens with 2 component spinors though?
This is true in the sense that if you act with a transformation matrix on every index (both spinor indices and the vector index), the gamma matrices are unchanged. This is equivalent to saying (as the OP did) that transforming the two spinor indices gives the same result as transforming only the vector index (actually by the inverse transformation).
The Lorentz transformation properties of Weyl fields are treated in mind-numbing detail in the QFT book by Srednicki, available free online.
lol thanks. I was worried I was being completely thick then. don't suppose you have a link do you for where I can see it for free? can't find it.
Im generally confused on this whole matter. Ultimately I want to perform a super poincare transformation on superspace. I.e a susy transform then a lorentz transform which I know how to do on the super space cos I have seen it in a book. Then I want to invert the transformation, so inverse lorentz then inverse susy.
oh cheers. Yeah I came across that page but didn't see the bit where it said 'click here' :lol:
Sorry that just made me look lazy.
Let me first say that you have a lot of mix-ups where inverse transformations should be transformations and transformations should be inverse transformations. I'm not just talking about using a different convention than what I'm used to - what you have is not internally consistent.
Anyways, if you're confused about how the 2-component Weyl spinors inside your 4-component Dirac spinors transform, try calculating the 4x4 spin-matrices. If you do that (in the Weyl basis), you should find that resulting matrix is block-diagonal, and that 2x2 Pauli matrices transform each 2-component Weyl spinor (the top should transform with opposite sign of the bottom - this is the result of left-handed and right-handed Weyl fields being related by the adjoint operation)
That's because I have been sloppy writing stuff.
  • · Replies 24 ·
  • · Replies 0 ·
