Iterated Function Sequences Accumulation: Help
  • Thread starter Thread starter aridneptune
    Function Sequences
The discussion focuses on the accumulation points of the iterated function sequence defined by the contractions A0, A1, and A2, which generate the Sierpinski right triangle. The user seeks to understand the behavior of the composite function (A1 ∘ A2)^n applied to an initial point . The user initially hypothesizes that iterating A2 after A1 converges to <0, 1>, but questions the validity of this assumption. The key conclusion is that the sequence accumulates at multiple points, necessitating a deeper analysis of the composite functions.
  • Understanding of iterated function systems (IFS)
  • Familiarity with contraction mappings
  • Knowledge of the Sierpinski triangle and its properties
  • Basic concepts of composite functions in mathematics
  • Explore the properties of contraction mappings in detail
  • Study the Sierpinski triangle's construction and its fractal nature
  • Learn about fixed points and their significance in iterative processes
  • Investigate the concept of accumulation points in sequences
Mathematics students, particularly those studying fractals, iterative systems, and contraction mappings, as well as educators looking for examples of complex function behavior.
aridneptune
We are given three contractions which generate the Sierpinski right triangle:
A0 = [tex]\frac{1}{2}[/tex] <x , y>
A1 = [tex]\frac{1}{2}[/tex] <x-1 , y> + <1 , 0>
A2 = [tex]\frac{1}{2}[/tex] <x , y-1> + <0 , 1>
We are asked to find the points on which the sequence
(A2[tex]\circ[/tex]A1)n(<x0 , y0>) ) -- that's (A1 COMPOSITE A2)n
accumulates.
Not quite sure how to approach this problem at all. I've figured that A1n takes any <x , y> to <1 , 0>, and that A2n takes any <x, y> to <0, 1>. So my first instinct was to say that iterating A2 n times on an n-iteration of A1 would just converge to <0 , 1>. However, I'm fairly sure this is incorrect. But how can this system accumulate on >1 point?
Any ideas/help would be greatly appreciated!
my first thought is to write the n-th iterators in terms of <x0,y0>, where the n-th iteration of A1 with be the initial point for the n-th iteration of A2.
Sorry -- correction it's (A1 COMPOSITE A2)n (fixed above). Increasing n increases both applications of A1 and of A2.
  • · Replies 40 ·
