How long will it take the zinc to reach the desired thickness?
  • Thread starter Thread starter rayhan619
    Thickness Zinc
The discussion revolves around calculating the time required to electroplate a zinc coating of 130 nm thickness on a copper sheet, given specific parameters such as current and density of zinc. The subject area includes electrochemistry and material science.
  • Participants discuss the calculation of volume and mass of zinc needed, explore the relationship between charge and time, and question unit consistency in their calculations.
Some participants have provided feedback on unit conversions and calculations, while others are re-evaluating their previous attempts. There is an ongoing exploration of the correct approach to arrive at the desired time for electroplating.
Participants are working under the constraints of a homework assignment, which may impose specific rules or expectations regarding the presentation of calculations and results.
rayhan619
For a science experiment you need to electroplate a 130 nm thick zinc coating onto both sides of a very thin, 3.0 cm*3.0 cm copper sheet. You know that the charge carriers in the ionic solution are divalent (charge 2e) zinc ions. The density of zinc is 7140 kg/m^3
If the electroplating apparatus operates at 1.3 mA, how long will it take the zinc to reach the desired thickness?
we know area and thickness of the plate and the density of the zinc, and the current.
so we can get the volume of the plate and using density we can figure out the mass.
volume = 3*10^-2* 3*10^-2* 130*10^-9 m = 1.17*10^-10 m^3
and the mass = 1.17*10^-12 m^3 * 7140 kg/m^3 = 8.35*10^-7 kg
in 1 mole the weight of zinc is 65.38 g
so in 8.35*10^-7 kg 1.3*10^-8 mole
1 mole we have 6.022*10^23 atoms
so in 1.3*10^-8 mole we have 1.3*10^-8 * 6.022*10^23 = 7.83*10^15 atoms
so number of electrons = 7.83*10^15 *2 = 1.57*10^16
1 Coulomb is equal to 6.241*10^18 electrons.
so 1.57*10^16 electron = 2.5*10^-3 C
I = Q/t
so t = Q/I
= 2.5*10^-3/1.3*10^-3
= 1.92 s
so for both side the total time would be 1.92*2 = 3.84 s
i tried plugging that number but apparently it was wrong.
Any ideas what i am doing wrong in here?
Any help would be appreciated.
Check the units, both kg and g appear here. Use one or the other.
yes you are right.
i redo the part.
does it look good?
so in 8.35*10^-7 kg 1.3*10^-5 mole
so in 1.3*10^-5 mole we have 1.3*10^-5 * 6.022*10^23 = 7.83*10^18 atoms
so number of electrons = 7.83*10^18 *2 = 1.57*10^19
so 1.57*10^19 electron = 2.5 C
I = Q/t
so t = Q/I
= 2.5/1.3*10^-3
= 1923 s
so for both side the total time would be 1923*2 = 3846 s
Looks good! Just watch the sig figs.
i tried putting 3.8*10^3 s
but that didnt work either.
donno what's wrong with this problem. : (
  • · Replies 21 ·
