Which Metal Should Be Used for Nickel Plating?
The discussion centers on the appropriate metal for nickel plating from a nickel (II) nitrate solution. Participants confirm that zinc is the suitable choice for the anode due to its lower standard reduction potential (-0.76 V) compared to copper (0.34 V) and nickel (0.23 V). The consensus is that nickel ions (Ni2+) are reduced to nickel metal (Ni(s)) at the cathode, where plating occurs. Mnemonics such as "An Ox Red Cat" are recommended for remembering the electrochemical processes involved.
  • Understanding of electrochemistry principles, specifically oxidation and reduction.
  • Familiarity with standard reduction potentials and their significance in electrochemical reactions.
  • Knowledge of galvanic cells and their components, including anodes and cathodes.
  • Basic understanding of nickel plating processes and applications.
  • Research the electrochemical series and its application in predicting spontaneous reactions.
  • Learn about the process of nickel plating, including preparation and post-treatment techniques.
  • Explore the use of different metals in plating and their effects on the quality of the plated surface.
  • Study the principles of galvanic cells and their practical applications in electroplating.
This discussion is beneficial for chemistry students, electroplating technicians, and professionals involved in surface finishing and metal treatment processes.
meganw
"Plating" Metal - Cathode or Anode?
You want to plate out nickel from a nickel (II) nitrate solution onto a piece of metal inserted into the solution.
Should you use copper or zinc or can you use either of these metals?
Standard Reduction Potentials Chart needed...
Hello everyone! I understand that oxidation occurs at the anode and that eduction occurs at the cathode, but I am confused how this plating would work.
I think Ni+ needs to become Ni(s). So Ni needs to be reduced, and gain electrons. So that means that the metal inserted needs to be the anode. But I just read somewhere in my book that the cathode is the site of metal plating. :-/
My aswer would be that it needs to be Zinc.
Zn = -.76 (electrons)
Ni2+ = -.23 (empty)
Cu = .34 (electrons)
Zinc would work because Copper giving up its electrons to a higher energy level (Ni) would not be spontaneous. Is this right? (There's no answer to these problems in our Zumdahl solution manual, thanks. ) =)
Thanks!
-Megan
https://en.m.wikipedia.org/wiki/Galvanic_series
Further down on the list reduces further up on the list. So zinc will work well, and copper not so much.
There are a few mnemonics to help with remembering electrochemistry. In this case, we have “An Ox Red Cat,” or oxidation occurs at the anode while reduction occurs at the cathode. So the Ni2+ is reduced to nickel metal (plated) at the cathode.
9K
