Calculating Spectrum Width with Diffraction Grating: Helpful Guide
  • Thread starter Thread starter Velocity
    Light
The calculation of spectrum width using a diffraction grating with 3000 lines/cm and white light wavelengths ranging from 400 nm to 750 nm results in a spectrum width of 375 cm at a distance of 100 cm from the grating. The formula used is Spectrum Width = (Distance between adjacent maxima) x (Number of lines on grating). The distance between adjacent maxima is determined using the formula: Distance = wavelength / (number of lines on grating x order of maxima), where the order of maxima is 2 for the second antinode. This approach utilizes the principles of diffraction similar to those in a 2-slit apparatus.
  • Understanding of diffraction grating principles
  • Familiarity with the formula dsinθ=mλ for maxima
  • Basic knowledge of wavelength measurements in nanometers
  • Ability to perform geometric calculations related to optics
  • Learn about the principles of diffraction and interference patterns
  • Study the application of the diffraction grating formula in different contexts
  • Explore the effects of varying wavelengths on spectrum width
  • Investigate the relationship between grating density and diffraction patterns
Students and professionals in physics, particularly those studying optics, as well as educators seeking to explain diffraction phenomena and spectrum calculations.
Velocity
This question really has me stumped..i would appreciate it if anyone could help me out
White light containing wavelengths of 400nm to 750 nm is shone normally onto a diffraction grating of 3000 lines/cm. Calculate the width of the spectrum that appears as the second antinode on a screen that is 100 cm away.
Is there a specific formula I can use to solve the question? If so then please help.. thanks:smile:
The condition for maxima/minima is the same as that of a 2-slit apparatus. For adjacent slits separated by a distance d, we must have:
dsinθ=mλ for maxima and
dsinθ=(m+1/2)λ for minima.
In both cases, m is an integer.
You use the information given about the grating to determine d and you use geometry to determine the displacement y of the antinodes on the screen. Note that your expression for y will depend on the wavelength λ.
Yes, there is a specific formula that can be used to solve this question. The formula is:
Spectrum Width = (distance between adjacent maxima) x (number of lines on grating)
First, we need to calculate the distance between adjacent maxima. This can be done using the formula:
Distance between adjacent maxima = wavelength / (number of lines on grating x order of maxima)
In this case, the order of maxima is 2 (since we are looking for the second antinode). So, the distance between adjacent maxima can be calculated as:
Distance between adjacent maxima = 750 nm / (3000 lines/cm x 2) = 0.125 cm
Now, we can plug this value into the first formula to calculate the spectrum width:
Spectrum Width = (0.125 cm) x (3000 lines/cm) = 375 cm
So, the spectrum width that appears as the second antinode on the screen 100 cm away is 375 cm.
27K
