Understanding Tension Force: Two Elephants Pulling a Rope
In the discussion titled "Understanding Tension Force: Two Elephants Pulling a Rope," it is established that when two elephants pull on opposite ends of a rope with a force of 10N each, the tension force experienced by the rope is 10N. This conclusion is based on Newton's third law, which states that for every action, there is an equal and opposite reaction. The tension in the rope remains constant at 10N, as the forces on both ends of the rope balance out, resulting in no net movement.
  • Understanding of Newton's Laws of Motion
  • Basic knowledge of force and tension concepts
  • Familiarity with static equilibrium principles
  • Ability to interpret free-body diagrams
  • Study Newton's Laws of Motion in detail
  • Learn about static equilibrium and its applications
  • Explore free-body diagram techniques for analyzing forces
  • Investigate real-world applications of tension in structures
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of tension and force in static systems.
oxnume
Two elephants are pulling on opposite ends of a rope each with 10N of force. What is the tension force experienced by the rope?
Not sure if there are any
I originally thought to just add the the two together because they are pulling in opposite directions, so that would be 20N. But after taking up this question in class my teacher said the answer is supposed to be 10N and didn't explain too clearly. Can someone please explain exactly why that is?
Welcome to PF!
Hi oxnume ! Welcome to PF! :smile:
Because that's the way tension is defined …
if a mass of 10N is hanging from a rope tied to the ceiling, then the force exerted by the rope on the mass is (obviously) 10N …
so, by Newton's third law, the mass is also exerting 10N on the rope …
and since the rope isn't moving, Newton's second law tells us that the forces on the two ends of the rope must add to zero …
so the ceiling is also exerting 10N on the rope
(and the rope is exerting 10N on the ceiling). :smile:
Tension of 10N means that every tiny little bit of the rope has 10N force on either side of it, holding it in place. :wink:
  • · Replies 38 ·
9K
