How do you work out the largest angular scale to which it is sensitive
  • Context: Graduate
  • Thread starter Thread starter Tomboland
    Angular Scale Work
The discussion centers on determining the largest angular scale sensitivity of a system using two telescopes separated by a distance B, observing a source at an angle alpha. The correlation output is derived from the equation exp[i*k*B*alpha*cos(theta)], leading to a sinc function representation. The largest angular scale sensitivity is identified when the sinc function reaches 0.5, with considerations for the frequency range delta(V) and the impact of chromatic aberration. The Michelson stellar interferometer is referenced as a relevant tool for understanding these principles.
  • Understanding of angular scales in astronomy
  • Familiarity with the principles of interferometry
  • Knowledge of sinc functions and their applications
  • Basic concepts of chromatic aberration in optical systems
  • Research the mathematical foundations of the sinc function in signal processing
  • Study the operational principles of the Michelson stellar interferometer
  • Explore the effects of chromatic aberration on telescope performance
  • Investigate methods for calculating angular resolution in astronomical observations
Astronomers, optical engineers, and students of astrophysics seeking to understand angular sensitivity in interferometric systems.
Tomboland
How do you work out the largest angular scale to which it is sensitive and the field-of-view and what frequency range it can be used?
Astronomy news on Phys.org
bump or what ever I still not sure about this
So you have 2 telescopes a distance B apart looking at an area of sky at an angle theta. Then place a source at a small angle away from theta, alpha. Then I can show, using small angle approx for alpha the corolated output of the system is proportional to expi[k.B.alpha.cos(theta)]
Then average over a top-hat from -delta(V)/2 to delta(V)/2 (V=frequency) to give a sinc function
sinc[pi.B.alpha.cos(theta).delta(V)/c] so from this how do you
so if we know B how do we calculate the largest angular scale to which it is sensitive? Writing this may have answered my own Q is it when sinc gets to 0.5 or some thing and what is the value of alpha? Seems fine now but what would you put as delta(V)? Does this depend on the size of the actual individual telescopes? If so how? When does chromatic abberation become important?
Since nobody else has responded, I'll answer with what little I know.
It sounds perhaps like you are describing a Michelson stellar interferometer. It has been many years since I read the details of how these work, and only remember that it involves an interference measurement using two telescopes some distance apart, and assuming some form for the source intensity (eg., uniform disk or top-hat in the case of a star).
You could try a google search on "Michelson stellar interferometer". Unfortunately wikipedia does not give any details.
Regards,
Mark
