Register to reply
Total charge through point on wire due to changing current on other wire
by dhqpwoe
Tags: charge, current, point, wire
Share this thread:
dhqpwoe
#1
Apr12-09, 08:46 PM
P: 9
A square loop, side a, resistance R, lies a distance s from an infinite straight wire that carries current I. Now someone cuts the wire, so that I drops to zero. In what direction does the induced current in the square loop flow, and what total charge passes a given point in the loop during the time the current flows.
2. Relevant equations
Integral{B dot dl} = mu_0 * I => B=mu_0*I/(2*pi*r)
emf=-d(Integral{B dot dA})/dt
emf=I_induced*R
3. The attempt at a solution
I say that the flux is mu_0*I*a/(2pi)*Integral(dr/r) where r goes from s to s+a. The solution key agrees with me except for on the limits, which it says are a to 2a. I'm hoping that I am right for the problem as written and that the problem statement should have the square be a distance a (not s) from the wire... Does this sound right, or am I altogether wrong?
Thanks!
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
dhqpwoe
#2
Apr13-09, 03:13 PM
P: 9
Is the solution key wrong? (Should I be integrating from s to s+a?)
Register to reply
Related Discussions
Wire Loops, Current, Magnetic Field, & Straight Wire HELP! Introductory Physics Homework 1
0.5V across 1.5m tungsten wire w/cross-sect. area 0.6 mm^2 - Find wire current Introductory Physics Homework 3
Strength of magnetic field from a current filled wire at a point Introductory Physics Homework 6
How to find total energy from a current-carrying long straight wire. Introductory Physics Homework 0
Charge and current in a wire Introductory Physics Homework 4
