Energy added to Ice- determine final temperature
The problem involves determining the final temperature of a 10 kg block of ice initially at -8°C after absorbing 4.17 x 10^6 J of heat. The discussion centers around the concepts of specific heat, latent heat of fusion, and energy transfer in phase changes.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculations needed to determine the energy required to raise the temperature of ice, melt it, and then raise the temperature of the resulting water. There is a focus on checking units and values used in the calculations, particularly the specific heat and latent heat values.
Some participants have provided helpful guidance regarding unit conversions and the correct values for specific heat and latent heat. Multiple interpretations of the calculations are being explored, and adjustments to the initial calculations have been suggested based on unit checks.
There are mentions of common mistakes related to unit labeling and the importance of using correct coefficients in calculations. Participants are reflecting on their approaches and correcting their values based on feedback.
markdflip
A 10 kg block of ice has a temperature of -8°C. The pressure is one atmosphere. The block absorbs 4.17 x10^6 J of heat. What is the final temperature of the liquid water?
Q=4.17x10^6J
T_0=-8
Mass=10kg
4184= specific heat of water
2000=specific heat of ice
333.5=latent heat of fusion
Q=mc(deltaT)
Q=mL
Q_1=mc(delta)T
Q_1=(10kg)(2000)(8°C)
Q_1=160,000J of energy was needed to raise the temperature to 0 degrees Celsius
Q_2=mL
Q_2=(10kg)(333.5)
Q_2=3335J of energy needed to change ice to water.
160,000J+3335J=163,335J of energy used.
4,170,000J-163,335J= 4,006,665J of energy left
4,006,665J=mc(delta)T
4,006,665J=(10kg)(4184)(delta)T
4,006,665/(10*4184)=deltaT
deltaT=95.761°C
95.761 degrees Celsius should be the final temperature according to my calculations.
I'm fairly sure the process is right, my money is there is something wrong with a coefficient, but I can't figure it out.
check your units for the heat of fusion
oh, that was in J/g...so that would be 333,550 J/Kg
That makes more sense, 674,500J would be left for the third step opposed to 4,006,665J
674,500J/(10*4184)=deltaT
DeltaT=16.12 degrees Celsius.
Sound realistic?
Yes - it takes an awful lot of energy to melt ice (hence the icecream headache)
quick tip - if you write a number down in a physics problem and it doesn't have a unit you are probably making a mistake!
Thanks for the help. I need to fix my habit of not writing labels with constants since I just get used to them cancelling out.
I replaced the specific energy wof ice with 2050 instead of 2000, and used the correct value of latent heat at 335000 and got 16.03, the correct answer.
Thank you so much for your help.
