Potential difference in parallel - capacitors
The discussion revolves around the behavior of capacitors when connected in parallel and then reconfigured in series without a battery. The specific capacitors involved are C1 = 3 µF and C2 = 9 µF, connected across an 11 V battery. Participants are exploring the potential difference across each capacitor after reconnection and the energy stored in the capacitors before and after the reconnection.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the initial conditions of the capacitors in parallel and the implications of reconnecting them in series. There are attempts to calculate total charge and capacitance, with some confusion about the formulas for series and parallel configurations. Questions arise regarding the correct application of voltage and charge relationships in both configurations.
Several participants are actively engaging with the problem, questioning the assumptions made about capacitance and voltage. Some guidance has been provided regarding the formulas for series and parallel connections, but there is no clear consensus on the correct approach or calculations. Participants express uncertainty about their calculations and seek clarification on specific points.
Participants are working under the constraints of a homework assignment, which may limit the information available for discussion. There is an emphasis on understanding the relationships between charge, voltage, and capacitance in different configurations of capacitors.
StuckInPhysic
potential difference in parallel -- capacitors
Two capacitors C1 = 3 µF and C2 = 9 µF are connected in parallel across a 11 V battery. They are carefully disconnected so that they are not discharged and are reconnected to each other with positive plate to negative plate and negative plate to positive plate (with no battery).
(a) Find the potential difference across each capacitor after they are connected.
(b) Find the initial and final energy stored in the capacitors.
related formulas:
C=Q/V
so far...
so this means that they are in parallel, store up charge, and then are disconnected and reconnected in series without battery yes?
since C(total)=12uF and Voltage = 11v (for both capacitors) I figured that the Q(total) = 1.32*10^-4 C
12uF = Q(tot)/11v
when I apply this total charge to the capacitors in a series (inverting everything) I get 1/3uF=V(1)/1.32*10^-4, V(1)= 44v
before I went on to solve for the other capacitor I submitted this but it was wrong. Where did I go wrong?
When connecting two capacitors in series the capacitance will decrease: Ct = (C1 * C2) / (C1 + C2) and the voltage will add: V1 + V2.
mmmk so (C1*C2 / C1+ C2) = C(tot) does the same as (1/C1 + 1/C2)^-1, when you say V(1) + V(2) = V(t) is that the same V as when the capacitors were connected in parallel? I'm still entirely confused...
No. It's the total capacitance of the two capacitors when they are in series, after you disconnect from the battery and connect them together in series. So "C(total)=12uF" is incorrect.
Yes. It's the voltages across the capacitors after you disconnect from the battery. Which of course will be V1 = 11 and V2 = 11.
When I wrote "12uF = Q(tot)/11v" I was applying that to the capacitors in parallel ie what I had described before. When in parallel this is how I approached:
1/3 uF = delta V(1) / Q
1/9 uF = delta V(2) / Q
where Q in both is the same and is the total charge accumulated by the capacitors when in parallel.
I also approached by combining to find delta V(tot):
(C1*C2 / C1 + C2) = (1/C1 + 1/C2)^-1 = C(tot) = delta V(tot) / Q =
delta V(1) + delta V(2) / Q... In doing this I found V(tot) = (1.32*10^-4)/2.25 = 5.87e-5 which... is.. wrong?
StuckInPhysic said:
(C1*C2 / C1 + C2) = (1/C1 + 1/C2)^-1 = C(tot) = delta V(tot) / Q = delta V(1) + delta V(2) / Q
Sorry I misread your original post. You are correct.
but I'm not... maybe small calculation errors somewhere... baaaagh
