Linear transformations and subspaces
The problem involves linear transformations and subspaces, specifically focusing on finding the matrix representation of a linear transformation T relative to a given basis B for R2. The transformation is defined by its action on the basis vectors b1 and b2.
  • Participants discuss the relationship between the transformation and the basis, with one participant attempting to derive the matrix representation based on the transformation's effects on the basis vectors. Questions arise regarding the correctness of the derived matrix and how changing the basis affects the transformation.
The discussion is ongoing, with participants exploring different aspects of the problem. Some guidance has been offered regarding checking the derived matrix against the transformation's action, and there is a recognition that changing the basis will alter the representation of T.
Participants are considering the implications of defining different bases and how this affects the transformation T. There is an acknowledgment of the need to express the transformation in terms of the standard basis when the basis vectors are redefined.
Deneb Cyg
Let B={b1,b2} be a basis for R2 and let T be the linear transformation R2 to R2 such that T(b1)=2b1+b2 and T(b2)=b2. Find the matrix of T relative to the basis B.
I know that the matrix I'm looking for needs to be 2x2 and that the standard matrix of a linear transformation is related to how the transformation would affect the identity matrix. However I don't understand how to relate it to the basis.
My best guess is:
T(b1)=2b1+b2
T(b2)=0b1+b2
so the matrix is [[2,0][1,1]]
But I'm not sure if this is right (if it is, I'm not sure why) or how to check it. Am I on the right track?
You know that the linear map sends (1,0) to (2,1) and (0,1) to (0,1) (read as columns). So all you need to do is check that your matrix does that, and in checking it you should see why you did what you did to get the answer.
Okay, that makes sense. The second part of the question is "suppose now that b1=(1,1) and b2=(1,2) (read as columns). Find the matrix of T relative to the standard basis of R2."
Would the answer for this be the same [[2,0][1,1]] as before because its the same transformation or does defining B and relating it to the standard basis instead change the answer?
Changing basis changes T. I assume that when b1=(1,1) this is b1 relative to the standard basis e1 and e2 (well, 'standard' doesn't matter - it's just another basis).
There are several ways to do this. You could just try to work out what Te1 and Te2 are from the action of T on b1 and b2 (e.g. note that e2=b2-b1, so you know what Te2 is now, but don't forget to express Te2 in terms of e1 and e2.).
  • · Replies 18 ·
