Can You Distribute 20 lbs of Pressure Oddly Across 5 Hours?
The problem involves distributing 20 lbs of pressure over 5 hours using only odd positive integers. The challenge is to find suitable values that meet these criteria without using even numbers or fractions.
  • Exploratory, Assumption checking
  • Participants explore the implications of using odd numbers and question the inclusion of zero as a valid value. Some discuss the mathematical properties of odd and even numbers in relation to the problem's requirements.
The discussion includes various interpretations of the problem's constraints, particularly regarding the acceptance of zero. Some participants suggest that if zero is not allowed, the problem may not have a solution, while others express skepticism about the problem's validity.
There is ambiguity regarding the definition of odd numbers and whether zero can be included in the solution set. The problem's constraints are strictly defined, leading to differing opinions on the feasibility of finding a solution.
reinaldo
Complex Mathematical Puzzle!
Distribute 20 lbs of pressure in 5 hours, the numbers Must be Odds and each hour must have a value; you can't use even numbers, nor frations, just positives completes!
which are the values??
Well technically 0 is a value, so
hour 1 = 17
hour 2 = 1
hour 3 = 1
hour 4 = 1
hour 5 = 0.
If 0 is not counted then there is no real solutions.
two odds always make an even. 2n+1 + 2n+1 = 4n+2. Since any integer 2n is always even, 4n is also always even. And any even number plus 2 is always even. This also implies 4 odds always make an even.
Then to add an odd to the even number makes it odd
Thus this problem has no solution.
If 0 is acceptable then it has a few solutions.
Zero isn't odd in any system of defining 'odd' I've ever heard of. I'm not sure what the point of this problem is. Anybody have any idea?
The answer is you can't
  • · Replies 69 ·
  • · Replies 0 ·
  • · Replies 32 ·
14K
