Thread Closed
Difference between voltage and voltage drop?
Share Thread Thread Tools
Apr26-09, 09:27 PM   #1
A power station delivers 440 kW of power through 3 ohm lines. How much power is wasted if it is delievered at 12000v?
2. Relevant equations
v=IR
P=I^2R
P=IV
3. The attempt at a solution
I believe you are supposed to solve it like this but I do not understand why:
I=P/V = 440000/12000=36.67 A
P lost =I^2R=(36.67)^2 (3) = 4033 W
But my gut instict tells me to do this which I believe is wrong from what I've read:
P=V^2/R = (12000)^2/3 = 4.8 x 10^7 W
P lost = P - Pused = (4.8 x 10^7 - 440000) =4.756 x 10^7W
I think I'm getting confused with what "V" is. I keep googling it and all I can tell is that I don't understand the different between voltage and voltage drop. I'm not clear what either is. Could anyone please explain?
Why does P=I^2R give you the power lost rather than the original power (440 kW) or the power used?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr26-09, 10:01 PM   #2
You cannot talk about voltage at a single point, you can only talk about a change in voltage. You'll notice that V = Ed, this is the difference in potential between the distance d.
Power is a change in energy and obvious way to look at it is to say that if there is a change in energy it has to be a negative since the resistor will heat up.
May18-10, 03:53 AM   #3
Quote by VenaCava View Post
No you are wrong. You cannot use V=12000V for calculating power loss [itex] P_{loss}[/itex] in line. You have use the voltage drop across the line to find [itex] P_{loss}[/itex].
Since we don't know that, (It is equal to difference between voltage at supply end ([itex] V_{s}[/itex]) and voltage at load end (12000V). Since we dont know [itex] V_{s}[/itex], but we know current through the line, we can find power lost directly from the relation
[itex] P_{loss}=I^{2}R[/tex]
Thread Closed
Thread Tools
Similar Threads for: Difference between voltage and voltage drop?
Thread Forum Replies
Voltage Drop Engineering, Comp Sci, & Technology Homework 3
voltage drop Introductory Physics Homework 3
Voltage Drop General Physics 2
voltage drop Electrical Engineering 1
Voltage drop Introductory Physics Homework 4
