How Do You Calculate Transformer Efficiency with Given Power and Voltage?
The discussion centers on calculating the efficiency of a transformer given specific power and voltage parameters. The primary power is stated as 13W, with a primary voltage of 120V and a secondary voltage of 12V. The turns ratio is indicated with an unknown primary turns count (Np) and a known secondary turns count (90). The efficiency formula used is eff = Psec / Pri * 100, highlighting the need for clarity on the turns ratio to accurately compute transformer efficiency.
  • Understanding of transformer basics, including primary and secondary voltages
  • Knowledge of power calculations in electrical circuits
  • Familiarity with the efficiency formula for transformers
  • Concept of turns ratio in transformers
  • Research the calculation of transformer efficiency using the formula eff = Psec / Pri * 100
  • Study the significance of turns ratio in transformer design and efficiency
  • Explore the impact of voltage levels on transformer performance
  • Learn about common transformer types and their efficiency characteristics
Electrical engineering students, professionals working with transformers, and anyone involved in power system analysis and efficiency optimization.
Nightwatchman
What is the the efficiency of a transformer with 13w of primary power.
120Vp, Np unknow
12Vs, 90Np
eff= Psec/ Pri * 100
120Vp, Np unknow
12Vs, 90Np
In first line you say Np is unknown and second line you say Np = 90. which is correct?
