Motion of a particle performing damped vibrations
The discussion revolves around two questions related to physics and mathematics: the work done by an air compressor and the motion of a particle performing damped vibrations. The first question seeks to demonstrate a condition for minimum work, while the second question involves finding maximum displacement and acceleration of a damped oscillating particle.
  • Stuart presents a formula for work done by an air compressor but notes confusion over the variable 'p' and the presence of a '-2' in the equation.
  • Some participants question the formulation of the work equation, suggesting possible typographical errors and the absence of 'p'.
  • Stuart describes the motion of a damped particle as given by the equation x=e^-t * sin 2t and attempts to find the maximum displacement and acceleration.
  • One participant clarifies that the motion represents a sine wave with exponentially decaying amplitude, indicating the nature of damped oscillations.
  • There is a discussion about finding local maxima by setting the derivative dx/dt to zero, with some participants providing alternative approaches to solve for t.
  • Stuart later acknowledges finding a maximum point but expresses uncertainty about the meaning of "maximum distance for the least positive value of t".
  • Another participant suggests that the question may be poorly worded and that the maximum distance refers to the global maximum occurring at the least t value.
  • One participant asserts that if k, p1, p2, and n are constants, the work done will also be constant, implying no differentiation with respect to n is necessary.
Participants express differing views on the formulation of the work equation and the interpretation of the damped oscillation problem. There is no consensus on the correct interpretation of the work done by the air compressor, and the discussion regarding the damped vibrations remains unresolved with multiple perspectives on finding maxima.
There are indications of potential typographical errors in the work equation, and the discussion includes various assumptions about the constants involved. The mathematical steps to find maxima and the implications of the damping factor are also not fully resolved.
stu
Hi
I have two questions to ask and hopefully someone could help as I am getting little help from my college and work collegues
1) The work done by an air compressor is given by
W = K [ (p1/p2)^(n-1/n) + (p1/p2)^(n-1/n)-2]
where p1,p2,n and K are all constants.
QUESTION - show that the work done is a minimum when p=sqrt(p1p2)
I have no idea where to start on this at all
2) motion of a particle performing damped vibrations is given by x=e^-t * sin 2t (x=displacement in metres and t=time in secs)
Find the times at which x is at a maximum and find the maximum distance for the least positive value of t. Find the acceleration at this point
I have found dx/dt and evaluated it for 0 This gives me an answer of t=31.6 (approx) but when i plug t=31.6 into dx/dt i come out with it equals 0, which suggests to me there is no maximum point but instead a point of inflection. That is about as far as i got on this question before i got stuck.
Any help on either of these question would be much appreciated as i have been trying to get my head around them for a while now with little or no success
Regards
Stuart
1) There's something missing here...specifically there's no 'p' in the expression for the work.
stu said:
Hi
What's "p"? Do you mean [itex]n = \sqrt{p_1p_2}[/itex]? Also, where exactly is that "-2"? Is it like this:
[tex]W = K \left [ { \left ( \frac{p_1}{p_2} \right ) }^{\left ( \frac{n-1}{n} \right ) } + { \left ( \frac{p_1}{p_2} \right ) }^{\left ( \frac{n-1}{n} \right ) } - 2 \right ][/tex]
[tex]W = 2K \left [ { \left ( \frac{p_1}{p_2} \right ) }^{\left ( \frac{n-1}{n} \right ) } - 1 \right ][/tex]
[tex]\frac{dW}{dn} = 2K \left [ \ln \left( \frac{p_1}{p_2} \right ){ \left ( \frac{p_1}{p_2} \right ) }^{\left ( \frac{n-1}{n} \right ) } (n^{-2}) \right ][/tex]
Regards
Stuart
There will be no points of inflection. If you graph this, you will see a sine wave with a decaying amplitude (that's what the [itex]e^{-t}[/itex] does), hence "damped oscillation."
[tex]x = e^{-t} \sin (2t)[/tex]
[tex]\frac{dx}{dt} = -e^{-t} \sin (2t) + 2e^{-t} \cos (2t)[/tex]
[tex]0 = e^{-t} [2 \cos (2t) - \sin (2t) ][/tex]
[tex]0 = 2 \cos (2t) - \sin (2t)[\tex]<br /> <br /> [tex]2 \cos (2t) = \sin (2t)[/tex]<br /> <br /> [tex]\tan (2t) = 2[/tex]<br /> <br /> [tex]2t \approx 1.1071487[/tex]<br /> <br /> [tex]t \approx 0.55357436[/tex]<br /> <br /> <br /> [tex]x \approx 0.51419838[/tex][/tex]
2) Understand what the oscillations look like - it's a sine wave that whose amplitude diminishes exponentially with time.
a) Times at which x is at a maximum : This suggests that you are looking for local maxima, which can be found where dx/dt=0 or tan(2t) = 2.
You get the solutions [tex]2t=tan^{-1}(2) + n\pi[/tex]
b) This seems to be the first local maximum, which will be greater than all others because of the exponential decay factor. It happens at n=0 or t=Pi*31.6/180 (since you must use radians NOT degrees).
c) The acceleration is found by substituting this value of t into [tex]\frac{d^2x} {dt^2}[/tex]
Of course it would, wouldn't it ? Only if you get zero in the second derivative, is it a point of inflection.
I think the -2 belongs inside the bracket. So the second exponent is (n-1)/(n-2)...only my guess ! Still...no p anywhere !
calculus
hi folks, thanks for getting back so fast.
Firstly, the format of the question is exactly how AKG showed it (how did you do that btw?). Secondly i am aware that there is no P anywhere in the question, but that is exactly how it is worded and it is not n=sqrt(p1p2).
As for the second question i must of been watching the footy last night to much as i have rechecked my figures today and have now found a maxima point, but i am still not sure what "and find the maximum distance for the least positive value of t" means or is that just a long winded version of saying what the maxima point is?
Thanks again for the help
Stuart
Search the forums for "LaTeX." There's a thread all about how to use it. Here is a pdf file that helps for starters.
Well that's ridiculous! If it's for homework, I wouldn't bother with the question, it looks like a typo. What's more, even if it were [itex]n = \sqrt{p_1p_2}[/itex] I don't think that works. The work I've shown so far on that problem leads to a result where no value of n will give a derivative of zero. Looking at the function itself, I don't see [itex]n = \sqrt{p_1p_2}[/itex] being of any significance. It depends on the signs and magnitudes of the various constants, but it appears to me that in some cases, there is no maximum, in some cases, the maximum is 0 (when n = 1), etc. Something's seriously wrong with the question.
Well, if you looked at a regular sine curve, you'd notice an infinite number of maximas. A curve such as this one will only have one global maximum, but just like the sine curve, it will have an infinite number of local maxima. Of all the local maxima and their corresponding t values, the global maximum actually occurs for the least t value, so I don't know why they bothered specifying that. Anyways, do a Yahoo! or Google search for "GCalc". The first link should take you to the GCalc page, and at the top is a link to use the GCalc applet. You should graph your function to understand what's going on. You'll notice what is meant by damped oscillation, and you'll see where the overall maximum distance occurs (as well as the local maximum distances). Actually, you see damped oscillation all the time. Hold a rope or cord or chain from your hand, and let it swing back and forth. You'll notice that the "size" of the swing slowly decreases and it eventually comes to a stop. The damped oscillation you're looking at is essentially the same (except it never comes to a stop, it continues oscillating in tiny little oscillations for ever, whereas your chain or rope will stop in real life).
If k,p1,p2,and n are constants then work will be constant,
there is no way diff it w.r.t n etc
10K
