Finding electric field 3 cm along a thin rod.
The discussion focuses on calculating the electric field at a point 3 cm along a thin rod of length 5.0 cm and total charge 8.4 nC. The correct formula for the electric field due to a line of charge is derived as E = KQ/(d*(d^2 + (L/2)^2)^(1/2)), where K is the Coulomb's constant (8.99 x 10^9 N m²/C²). The user initially misapplied the formula, resulting in an incorrect value of 64458.88 N/C, while the correct calculation yields an electric field of approximately 2.7 x 10^5 N/C using the appropriate integration method.
  • Understanding of electric fields and Coulomb's law
  • Familiarity with integration techniques in physics
  • Knowledge of linear charge density
  • Basic concepts of electrostatics
  • Study the derivation of the electric field for continuous charge distributions
  • Learn about integration techniques for calculating electric fields
  • Explore the concept of linear charge density and its applications
  • Review the principles of electrostatics and Coulomb's law in detail
Students in physics, particularly those studying electrostatics, as well as educators and anyone seeking to understand electric field calculations for charged objects.
jheld
The figure shows a thin rod of length L = 5.0 cm with total charge Q = 8.4 nC. What is the magnitude of the electric field E at x = 3.0 cm?
Figure in the attachment
E = Kq/r^2
K = 8.99 * 10^9 N m^2/C^2;
r is the distance between the point and the charge.
Field for a line of charge:
We have Q, L and "d". But I am still unable to get the answer.
When I plug in the values as they are (as what I think they are), I get 64458.88
Answer is: 2.7*10^5 N/C.
But, when I use linear charge density lambda = Q/L.
E = lambda/4*pi*epsilon_0 * distance, I get 2.2634 N/C. Do you think this is the right way to get it?
I am not sure why that equation does not work.
Field due to a small charge element at the point is given by
dE = k*dQ/r^2.
dQ = Q/L*dr
Hence E = Integration(dE) = k*Q/L*Int(dr/r^2).
Find the lower and upper limit of r,Substitute it in the integration to get the field.
  • · Replies 16 ·
  • · Replies 35 ·
