Proving R is a Field: Finitely Generated R-Modules
  • Context: Graduate
  • Thread starter Thread starter sanctifier
    Field
The discussion revolves around proving that a nonzero commutative ring R with identity is a field if every finitely generated R-module is free. Participants explore the implications of this property and seek assistance in completing the proof.
  • One participant notes that if every finitely generated R-module is free, then the R-module R itself is free, as it is generated by {1}.
  • Another participant suggests considering the ideal I of R and the R-module R/I, indicating that if R/I is free, it provides information about the ideal I.
  • A participant seeks clarification on the term "cyclic" and expresses uncertainty about some terminology used in the discussion.
  • It is explained that R/I is cyclic because it can be generated by a single element, specifically the coset 1 + I, and that this leads to the conclusion that R/I must be free.
  • One participant proposes that a field can be defined as a ring with no nontrivial ideals and questions the contradiction that arises if R/I is free while I is not zero or R.
  • A later reply presents a reasoning involving elements v in M\I and i in I, discussing the concept of relative primality and the existence of multiplicative inverses.
Participants express different levels of understanding regarding the proof and terminology, and while some points are clarified, the overall discussion remains unresolved with multiple competing views on the proof's completion.
Some participants express uncertainty about specific terms and concepts, indicating potential limitations in their understanding of the mathematical framework being discussed.
sanctifier
Notations:
R denotes a commutative ring with identity
Terms:
R-module: a module whose base ring is R
Question:
Prove that if a nonzero commutative ring R with identity has the property that every finitely generated R-module is free then R is a field.
Idon't know how to complete the proof. The only thing I know is that if every finitely generated R-module is free then R-module R is also free, since it's generated by {1}.
Thanks for any help!
Hint: If I is an ideal of R, then R/I is a cyclic (in particular, finitely generated) R-module. If R/I is free, what does this tell you about I?
Thanks for reply! VKint
What exactly does the term cyclic mean here? I am not familar with some terms.
There may be some grammatical mistakes above, sorry for that, I've done my best to express what I want to say.
By cyclic, I mean that the module [tex]R/I[/tex] can be generated by just one element (i.e., the coset [tex]1 + I[/tex]) over [tex]R[/tex]. Thus, since [tex]R/I[/tex] is finitely generated, you can apply your assumption to the [tex]R[/tex]-module [tex]R/I[/tex] to conclude that [tex]R/I[/tex] must be free.
One way of defining a field is as a ring with no nontrivial ideals. Thus, all you need to show is that [tex]R[/tex] can't have any nonzero ideals (besides itself, of course). Can you see why it would be contradictory for [tex]R/I[/tex] to be free if [tex]I[/tex] were not either [tex]0[/tex] or [tex]R[/tex]?
VKint, I had some trouble in my work recently, so I didn't reply in time, I'm sorry.
I don't kown whether the following is right, may you can help me again, thanks a lot!
If v∈M\I and i∈I, then v and any i are relatively prime, if not, then there's a scalar s which divides both v and i, then s is contained in I, otherwise the scalar i divided by s doesn't belong to I.
So, there exist scalars s1 and s2 for which s1v + s2i = 1,
then s1v + s2i + I = 1 + I → s1v + I = 1 + I
since s2i∈I, so s1v=1, that is to say s1 IS the multiplicative inverse of v.
The left could be solved by induction.
  • · Replies 24 ·
