Help Answer Review Questions by Friday Morning
  • Thread starter Thread starter ChemRookie
    Review
The discussion revolves around a set of review questions related to chemistry, specifically focusing on the separation of metal ions through precipitation, the evaluation of fertilizers based on nitrogen content, and calculations involving the preparation of a saturated solution. The scope includes conceptual understanding and mathematical reasoning.
  • Homework-related
  • One participant suggests adding HCl to precipitate silver as AgCl, followed by filtering out barium and iron, and then adding H2SO4 to precipitate BaSO4 while leaving iron in solution.
  • Another participant proposes calculating the molar masses of NH3 and NH4NO3 to determine which fertilizer has a greater fraction of nitrogen by mass.
  • A different participant explains that to find the number of moles of BaF2, one should multiply the concentration by the volume, and then use the molar mass to find the mass needed.
  • One participant notes that for Question 1, it is important to introduce an ion that will react with the metal ions to form an insoluble compound, emphasizing the need for a systematic approach to the reactions involved.
  • Another participant reiterates that Question 2 involves determining which fertilizer has the most nitrogen by comparing the molar masses and nitrogen content.
  • For Question 3, it is mentioned that concentration is in moles per liter, and the mass is determined by multiplying the number of moles by the molar mass.
Participants generally agree on the methods for Questions 2 and 3, but there is uncertainty and a lack of consensus on the approach to Question 1, with one participant requesting further clarification on the steps involved.
There are unresolved aspects regarding the specific ions to be introduced for the precipitation in Question 1, as well as the overall strategy for the sequence of reactions needed to separate the metal ions.
Students preparing for chemistry exams, particularly those focusing on topics related to ion separation, fertilizer composition, and solution preparation calculations.
ChemRookie
Doing a review for exams but some word type questions I don't understand, and another question that's not word type.
Anybody that can answer please do, I do need to know to do it by Friday morning.
Here they are...
Question 1...
An industrial plant is confronted with a problem of seperating the metal ions found in a large vat of solution. By analysis, the solution was found to contain varying quanties of silver, barium and Iron(III) ions. Suggest a procedure for seperating the metal ions by precipitation.
Question 2...
Fertilizer is used to replace depleted nutrients in soil. Liquid ammonia and ammonium nitrate are used to replace needed nitrogen in the soil. Based on the percentage of nitrogen by mass, which of these would be better fertilizers ? Assume cost is the same (per kilogram).
and one number question:
A chemist wishes to preare 200ml of a saturated solution of BaF2, the concentration of which is 6.3 * 10-3mol/L. Determine the mass of BaF2 that will be needed to make up the 200mL of solution.
Chemistry news on Phys.org
1) Add HCl to precipitate the Silver ans AgCl, filter out the rest (Barium + Iron)
Add H2SO4, the Iron dissolves but BaSO4 forms a precipitate. Filter again, and you're left with only the Iron.
2) Calculate the molar masses of NH3 and NH4NO3. The first contains 1 mole (14g) of nitrogen while the second contains 2 moles (28 g) of nitrogen. Which has a greater fraction of nitrogen ?
3) Find the number of moles of BaF2 in the solution by multiplying concentration with volume (why is this true ?). Multiply this by the molecular weight (or molar mass) to get the weight.
Question 1 is kind of tough.
You want to introduce an ion (or ions) which will react with the metal ions to form an insoluble substance. So, you need to look at your periodic table and figure out which ions the metal will form an ionic bond with. The resulting compound has to be insoluble if you're removing the ions by precipitation - you should have a chart explaining how to determine if a compound is soluble or insoluble.
The tough part is that just saying you're going to insert the ions probably isn't enough. You need to introduce a substance in which the metal ions will replace one of the elements of the compound you put into the solution, which means you'll now have a different ion in the substance. So you it's going to take a bit of thought to set up a string of reactions which will eventually remove all of the ions.
Question 2 is just a matter of figuring out which has the most nitrogen. You figure this out by using the molar mass of each and determining which has the most nitrogen per kilogram
Question 3 - concentration is in moles per liter. You figure out the number of moles of the BaF2 by multiplying the concentration by the volume. Once you have the number of moles, you determine the mass by multiplying by the molar mass.
Thanks for the quick responses guys. Great explanations BTW, had no problems figuring out #2 and #3. I do have issues understading #1, so if one of you could show the work on how you got to that, be great.
  • · Replies 16 ·
