Thread Closed
current density at the surface of a magnetised material
Share Thread Thread Tools
May14-09, 10:45 AM   #1
Write down an expression for the current density per unit length flowing at the surface of a magnetised material.
3. The attempt at a solution
Any ideas?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May14-09, 02:22 PM   #2
Recognitions:
Homework Helper Homework Help
E is the electric field, but there's no electric field in this problem, so that equation can't apply, can it?
It sounds to me like the problem is talking about the density of bound current. There's a simple expression for that in terms of the magnetization... you can look it up, or if you think about it you can probably come up with the relation on your own. (It might help to imagine each atom of the magnetized material as a tiny little current loop)
May14-09, 02:31 PM   #3
Recognitions:
You've written down Ohm's law which isn't the right equation to use. I think you're looking for [itex]\vec{K}[/itex], the surface current density, K is the current per unit width perpendicular to the flow?
May19-09, 01:07 PM   #4
Sorted! Its I=M X n
Thread Closed
Thread Tools
Similar Threads for: current density at the surface of a magnetised material
Thread Forum Replies
Electric field density at the surface of a current carring wire Introductory Physics Homework 2
time-dependent surface current density Advanced Physics Homework 1
Finding diameter of a wire based on the current and current density. Introductory Physics Homework 1
K, the "idealized surface current density" Introductory Physics Homework 4
Can I get Surface Density from Volume Density? Classical Physics 3
