Investigate Plants: High School Research Ideas
  • Thread starter Thread starter hikki_pop
    Research
The discussion revolves around generating ideas for simple investigative research projects related to plants suitable for high school students. The focus includes experimental design, particularly concerning the effects of various chemicals and nutrients on plant growth.
  • Homework-related
  • Some participants suggest investigating the effects of different levels of chemicals and nutrients on plant growth.
  • One participant proposes comparing different sources of nitrogen, such as ammonia versus nitrates, to observe changes in plant growth.
  • Another participant raises concerns about the safety of using pesticides and recommends focusing on various plant foods with different nutrient ratios instead.
  • A participant emphasizes the importance of establishing controls in the experiment, including positive and negative controls, to ensure valid results.
  • Participants discuss the need to standardize other variables, such as water, soil, and light exposure, to isolate the effect of the chosen fertilizer or nutrient.
Participants generally agree on the importance of using different nutrients and establishing controls, but there is no consensus on the specific chemicals or nutrients to use, nor on the safety of certain options like pesticides.
Limitations include the need for clarity on the specific ratios of nutrients in fertilizers and the potential risks associated with using certain chemicals. The discussion does not resolve which specific experimental designs are most appropriate.
hikki_pop
has anyone got some ideas on a good, yet simple high school type of investigative research related to plants?? 0_o thanks for your help!
Biology news on Phys.org
You could look at the effect of different level of chemicals and nutrient on the growth of the plant.
cool! that sound good! ^_^ hmm... can you give some ideas on any chemicals and nutrients which can be suitable for the experiment?? :smile:
Plant need nitrogen, phosphorus and potassium as their basic nutrient. What you could do is used different mixture and form of these elements. For example, you can compare two or more different source of nitrogen such as ammonia vs nitrates (this a common comparison) and see if there is change in plant growth. For chemicals you could any product in your house or pesticide from the local store.
oh wow! thanks~ :)
Pesticides can be pretty dangerous to work with, so those might not be the best choice. Instead, maybe use different kinds of plant foods (the nutrient suggestion). When you read the label on plant food, they often list right on the front 3 numbers, those correspond to the ratios of nutrients in the fertilizer, though I can't recall which one is which (ask someone who works at the store). Try plant foods with different ratios. Often those are intended for different plants, for example tulip food will have a different ratio than tomato food than grass food. However, if you try this, what will you use as controls? That's going to be important if you are doing this for a high school project (or any experiment). You need something that you know should help your plant grow (positive control) and something that you know should have no effect on plant growth (negative control).
Also make sure everything else is the same, like measuring the amount of water you put on each plant so they all get the same and planting each in the same amount of soil all from the same bag and try to keep them all the same distance from your light source (or rotate them daily so they all get equal time being close to the source or far from the source)...this way you only have one variable, amount of fertilizer (or whatever you choose to vary).
  • · Replies 20 ·
