Thread Closed
Infrared Distance Sensor
Share Thread Thread Tools
May15-09, 03:36 AM   #1
Dear Experts,
I bought a pair of infrared LEDs (transmitter + receiver).
I read that infrared can be used as distance sensor.
I have seen projects using it (eg. Sharp GP2D120 sensor) for robotics and toy cars. Just to clarify, I am not using the Sharp sensor but a normal infrared LED pair bought from an electronics parts store.
I tested it and measured with volt meter and it seems that different materials or objects reflect different intensity of infrared to the receiver.
I am wondering how can this be used as Distance sensor when there is no consistent voltage when sensing different materials.
Are there Infrared sensors that can measure distance accurately for different materials like wood, metal, plastic, concrete surfaces or materials?
Has anyone tried the Sharp sensor before? There are a few models of it.
At the moment, based on my testing , it fail to see how infrared led can measure distance accurately.
So, could you please help clarify my doubts.
Thank you very much.
Best regards
Ramone
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
May15-09, 07:24 AM   #2
Recognitions:
Gold Membership Gold Member
I think you've missunderstood how these things work. Sensors like these generally operate by modulating the light (or sound, the principle is the same for acoustic sensors) using an on-board oscillator and then down-mixing the reflected signal; i.e the measurement is based on time, not intensity.
You should be able to find a datasheet if you google a bit.
May15-09, 10:01 AM   #3
Recognitions:
If you mount the IR LED and IR Receiver on the front of your toy car, so that they can't see each other, (put a barrier between them), then when there is something to reflect off, the receiver will get some IR signal.
To avoid just any IR signal giving a false reading, you could modulate the transmitting IR LED with a 1000 Hz square wave to turn it on and off rapidly.
You then detect this on the receive end with a NE567 tone decoder or similar device.
Just the presence of this signal would tell your car that it is close to something and it is time to put the brakes on or turn away.
I doubt if you could really measure distance with such a device because the time interval would be so short. Infra Red light travels at the speed of light, of course. I make it about 30cm per nanosecond.
May15-09, 11:58 AM   #4
Recognitions:
I had a quick look at this particular sensor, and I am pretty sure it does NOT use time as I suggested above; I think it just uses triangulation (back to basics). I.e. it has a reciever with a number of "pixels" in it distributed over some distance from the transmitted. This also explains the short range (it is limited by the width of the sensor).
By sensing the posisiton of the maxium you the angles and then the distance.
If you look in the datasheet is seems to be quite accurate, and there is not much difference between grey and reflective surfaces.
(It does use a modulated signal, but that is probably just part of a PLL to get a better S/N ratio).
Thread Closed
Tags
infrared sensor
Thread Tools
Similar Threads for: Infrared Distance Sensor
Thread Forum Replies
long range distance sensor Electrical Engineering 4
Sensor to find distance. Classical Physics 6
investigate how output from photocell depends on distance from infrared point source Advanced Physics Homework 1
my infrared methane sensor is decreasing ,can you help me? General Physics 0
infrared static earth sensor modelling Mechanical Engineering 1
