Fix Electric Motor on Dryer - Get Help Now!
The discussion focuses on troubleshooting an electric motor issue in a dryer, where the entire motor box appears to be attempting to turn instead of just the gear. A seized bearing is identified as a potential cause, and it is recommended to remove the motor assembly for inspection. Users should check for metal shavings and test the motor separately with a power source, such as a car battery, to diagnose the problem effectively. Ultimately, purchasing a new dryer may be the most practical solution if repairs are too complex.
  • Understanding of electric motor components
  • Familiarity with dryer assembly and disassembly
  • Basic electrical testing techniques
  • Knowledge of mechanical systems, including gearboxes and pulleys
  • Research how to safely disassemble a dryer motor assembly
  • Learn about diagnosing electric motor issues
  • Explore methods for testing electric motors with a car battery
  • Investigate common dryer motor replacement options and costs
DIY enthusiasts, appliance repair technicians, and anyone troubleshooting electric motor issues in dryers.
Aces2High
im working on my dryer motor. its just an electric motor. i turn it on and it seems like the whole motor box is trying to turn instead of just the gear like its stuck or something. does anyone have clue. thanks.
I've never actually messed with a dryer before, but there are only so many moving parts to a motor/gearbox combo.
First of all, are you certain it is a gear box, and not a pulley system? It sounds like a bearing has seized up somewhere, preventing the system from turning.
Your best bet to truly find out what is going on would be to remove the entire motor assembly. Inspect any moving parts (pulleys, and what not). Look for metal shavings.
Once you removed the motor, try to spin the dryer portion by hand. If this spins, it is somewhere in the power train (gearbox or pulleys, which ever.)
Once you remove the motor, hook power back up to it carefully, and see if you can get it to spin without being installed. You can probably use a car battery to safely test it. (maybe not though, I'm not sure of power requirements and what not).
In short, you'd be better off to pick up a news paper and find a good deal on a new dryer.
And be patient, things don't get answered instantly. Someone smarter then me will eventually set you on the correct path. Don't go making other threads on the same topic :)
