Calculating Electron Trajectory in an Electric Field
The problem involves calculating the trajectory of an electron accelerated through a potential difference in an electric field, specifically from a filament to a metal grid and then towards a metal plate. The context is set within a vacuum tube where the electron's motion is influenced by the electric potentials of the grid and plate.
  • Participants discuss the relationship between work done and potential energy, with some questioning how to determine the force acting on the electron. There are hints provided regarding the work-energy theorem and conservation of energy.
The discussion is active, with participants offering hints and exploring concepts related to work and energy. There is an ongoing inquiry into the relationship between work done and kinetic energy, indicating a productive exploration of the topic.
Participants are navigating the problem with limited initial information and are attempting to clarify the relevant equations and concepts without arriving at a definitive solution.
rhettfraser
An electron is accelerated from the filament in a vacuum tube towards a metal grid which is maintained at a potential of 180 Volts. It goes through one of the holes in the grid and continues towards a metal plate 1.2 cm away which is maintained at a potential of -10.0 Volts.
How close to the plate does the electron get?
Im not sure, maybe something to do with Potential Difference
I don't know where to start
Welcome to PF!
Hi rhettfraser! Welcome to PF! :smile:
Hint: work done = ∫ force"dot"distance = ∫ electric-field"dot"charge, and the electron will stop when the KE is zero. :wink:
thanks
but how do you find the force?
uhh? you don't, you use ∫ electric-field"dot"charge :smile:
ok now I've worked out that the work done is 3.04x10-17
how should i work out that when KE is zero the electron will stop?
I know that W= Change in PE, is there anyway that W is related to KE?
Conservation of energy … KE + PE = constant :smile:
(or work-energy theorem …KE + W = constant)
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 44 ·
  • · Replies 26 ·
  • · Replies 18 ·
