Understanting the icl7107(adc with display)
  • Thread starter Thread starter smuscat
The ICL7107 ADC operates with a 200mV configuration, where the analog ground is floating with respect to the power supply. This design necessitates isolating the power supply from the analog input to ensure accurate measurements. The reference voltage is connected between the 9V supply and the analog ground rather than the power supply ground to maintain this isolation and prevent interference.
  • Understanding of ICL7107 ADC specifications
  • Knowledge of analog ground concepts
  • Familiarity with voltage reference configurations
  • Basic principles of power supply isolation
  • Research ICL7107 datasheet for detailed specifications
  • Learn about analog ground isolation techniques
  • Explore voltage reference circuit design
  • Study power supply design for sensitive analog applications
Electronics engineers, hobbyists working with ADCs, and anyone involved in designing circuits that require precise analog measurements.
smuscat
I am attempting to understand the 200mV configuration of th icl7107 (fig 1) in the datsheet attached. My question is the analogue ground shorted internally with the power of chip? or is it floating with respect to the supply? Thanks
it's floating with respect to the power supply, that's why you have to isolate the power supply of the chip from the analog input being measured.
why is the reference voltage is connected between the 9V supply and the analogue ground?instead connected by the ground of the power supply?
  • · Replies 16 ·
  • · Replies 24 ·
