| Thread Closed |
adjust full scale in an orifice flowmeter |
Share Thread | Thread Tools |
| May20-09, 12:13 PM | #1 |
Hi everybody!
I hope somebody can help me... We are using a plate orifice to measure water feed to a reboiler; the pipeline size is 1" and the orifice was initially designed for 0-1800 kg/h of water, with a maximum pressure drop of 1000 mm water. As water feed doubles may I simply change pressure drop - by doubling the higher value of scale - to obtain water flow? Thank you ( ang forgive for my bad english...) |
| May20-09, 01:16 PM | #2 |
Considering that water has virtually no viscosity and the changes in rheology due to pressure and temperature are negligible, I'd say you could assume a linear relationship between pressure drop and volumetric flow.
This is not the case for other fluids: oil-based and gases (water vapor included). EDIT: I'm not sure what a "reboiler" is: I'm assuming that a single-phase fluid (clean liquid water) is flowing through your orifice meter. If you're dealing with more than one phase (suspended solids, gases), you won't get a reliable measurement using an orifice plate meter. |
| May20-09, 02:42 PM | #3 |
Recognitions:
Ummm...the flow rate through an orifice is a function of the square root of the delta P. You might want to rethink that aspect. You will, most likely, introduce a bot more error by keeping the flow coefficient constant, but it shouldn't be a very large amount.
| Thread Closed |
| Thread Tools | |
Similar Threads for: adjust full scale in an orifice flowmeter
| Simple flowmeter design | Engineering Systems & Design | 18 | ||
| Full-scale deflection? | Introductory Physics Homework | 2 | ||
| how do i make a flow meter | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Arcing Flowmeter Phenomenon | General Physics | 5 | ||
