Gibbs energy of formation and electrolysis efficiency
The discussion centers on the relationship between Gibbs energy of formation and the efficiency of electrolysis. The Gibbs energy of formation for water is established at 237.18 kJ/mol, which corresponds to the electrical energy required to dissociate water into hydrogen and oxygen. Using Faraday's law, the calculations demonstrate that 107.205 Amps over one hour can produce 73.338 liters of gas at 100% efficiency. The derived voltage of 1.23V confirms that Gibbs energy is directly proportional to the electrical input energy needed for electrolysis, although real-world conditions will result in higher voltage due to inefficiencies.
  • Understanding of Gibbs Free Energy and its significance in thermodynamics
  • Familiarity with Faraday's Law of electrolysis
  • Basic knowledge of electrochemical reactions and stoichiometry
  • Ability to perform unit conversions between energy, power, and electrical parameters
  • Study the implications of Gibbs Free Energy in electrochemical systems
  • Learn about the factors affecting electrolysis efficiency and energy losses
  • Explore advanced electrolysis techniques and their applications in hydrogen production
  • Investigate the role of Faraday's constant in various electrochemical reactions
Researchers, chemists, and engineers involved in electrochemistry, particularly those focusing on hydrogen production and energy efficiency in electrolysis processes.
nuby
Hello -
I'm having some problems understanding Gibbs energy of formation, and how it's applied to electrolysis. So, I'm hoping someone can explain what I'm doing wrong..
According to his site: http://hyperphysics.phy-astr.gsu.edu/Hbase/thermo/electrol.html (image)
The change in the Gibbs energy of formation is the same as the electrical input energy required to disassociate one mole of water.. Which I've been told isn't correct. But it seemed to work with the following calculations/assumptions
Here's what I did...
According to Faraday law:
107.205 Amps in a cell over one hour should generate 73.338 Liters of (2 moles H2 and 1 mole O2) at 100 percent efficiency (at 25C 101.325 kPa)
Then I tried using the "Gibbs Energy of Formation" to double check the Faraday efficiency. With information from: http://hyperphysics.phy-astr.gsu.edu.../electrol.html At 25C and 101.325 kPa the change in Gibbs Energy of formation is 237.18 kilojoules / mol ...
Which I assumed meant 237.18 (kJ / mol) of electrical input energy is required to convert 1 mole of H2O into 1 mole of H2 gas and a 1/2 mole of O2 gas (at 25C and 101.325 kPa) at 100 percent efficiency.
So with the above Faraday calculations: 107.205 Amps continuous for 1 Hour will create 2 moles of H2 and 1 mole of O2 gas (3 moles total), which has a volume of 73.338 Liters.
Then I assumed if I multiply the Gibbs Free Energy of formation (energy used to create 1.5 moles of gas) by 2, I should have the actual energy required for 3 moles of gas (at 100 percent efficiency, in the above conditions).
237.18 kJ * 2 = 474.36 kJ
Convert 474.36 kJ to Watts:
474360 Joules / 3600 seconds = 131.7666 Watts
Then I put Faraday and "Gibbs" efficiency together..
131.7666 Watts = 107.204 Amp * Volts
So, V = (131.7666 W) / (107.204 A)
V = 1.23 VoltsWhich seems to imply deltaG is related to the electrical input energy required to disassociate 1 mole of water (at 25C 101.325 kPa)r. Is this right? If not, can you explain what I'm doing?
Thanks in advance.
Chemistry news on Phys.org
Anyone?
nuby said:
Which seems to imply deltaG is related to the electrical input energy required to disassociate 1 mole of water...
Thats because it is. You can think of the gibbs free energy as the energy required to split the water molecules apart or the energy released when they are combined (enthalpy of formation). To understand this more clearly with electrical work we can apply the first law of thermodynamics and Faraday's Law and take 1 mole of H2O as our system.
Energy into H2O = Energy used by breaking H2O bonds
Voltage x Current = Gibbs Free Energy (dG)
Since we know that the current is proportional to the number of electrons being redoxed in the reaction and that electrical charge is quantized, we can state that I = n x F. F is Faraday's constant (#moles x electron charge) and n is the number of electrons being transferred in the reaction (1 electron from each H). So,
V x n x F = dG
Solving for Voltage,
V = dG/nF = 1.23V (at STP)
From this relationship you can see that the electrical input is directly proportional to the gibbs free energy. More importantly, the current is directly proportional to the production rate of the reaction. In reality, the voltage will always be higher than 1.23V do to losses.
9K
20K
10K
