What Are the Space-Time Coordinates of an Event in a Different Frame?
The discussion revolves around the application of Lorentz transformations in special relativity, specifically concerning the space-time coordinates of events as observed in different inertial frames. Participants explore the implications of velocity on measurements of time and length, as well as the transformation of angles between frames.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants attempt to apply Lorentz transformations to convert space-time coordinates from one frame to another, questioning their arithmetic and the correctness of their application of the formulas.
  • Some participants raise questions about the proper length and how it relates to measurements in different frames, exploring the transformation of angles and lengths.
  • There is discussion about the conditions under which two events can be simultaneous in a different frame, with attempts to derive the necessary velocity for such a frame.
The discussion is ongoing, with participants providing feedback on each other's calculations and reasoning. Some have offered guidance on the application of formulas, while others are still clarifying their understanding of concepts such as proper length and the transformation of angles. There is a recognition of the complexity of the topic, with various interpretations being explored.
Participants express uncertainty about their calculations and the implications of their assumptions, particularly regarding the proper length and the effects of relativistic velocities on measurements. There is also mention of the need to express results in terms of original variables from the S' frame.
forty
Question 1:
An event occurs at x'=60m, t'= 8*10^-8s in frame S' (with y'=0 and z'=0) The frame S' has a velocity of 3c/5 in the x direction with respect to the frame S. The origins of S and S' coincide at t=0,t'=0. What are the space time coordinates of the event in S?
Just want to make sure I'm using the Lorentz formulas properly..
ɣ=(1 - v2/c2)-1/2
x = ɣ(x'+vt) = (1-(9/25))-1/2*(60+(3c/5)*(8*10^-8))=93m
t = ɣ(t' + (vx'/c^2)) = (1-(9/25))-1/2*((8*10^-8)+(3c/5c^2)*(60))=45s (For some reason I think this is very wrong)
Question 2:
The space time coordinates of two events measured in the frame S are as follows:
Event 1: x1=xo, t1=xo/c
Event 2: x2=2xo, t1=xo/2c
(a) There exists a frame in which these events occur at the same time. Find the velocity of this frame with respect to S.
(b) What is the value of t at which both events occur in the new frame.
(a) Would doing the following work?
ɣ(t1 + (vx1/c2))=ɣ(t2 + (vx2/c2))
then solve for v which gives v=-c/2 (again I don't think this is right)
(b)
ɣ=(1 - v2/c2)-1/2
Then using the value of v from a and the equation t'=ɣ(t - vx/c2) solve for t'
Any help on this would be greatly appreciated... This is a lot more confusing than I first anticipated.
ɣ=(1 - v2/c2)-1/2
You have the correct formulas, but I get a different value for t. Double check your arithmetic.
Question 2:
Looks OK to me.
(b)
ɣ=(1 - v2/c2)-1/2
That should work.
Double checked my value of t and get 2.5*10^-7 which seems better...
While I'm on a roll...!
(a) In frame S', a stick makes an angle of θ' with the x' axis. What is the angle θ measured in the S frame. What is the length in the S frame.
I presume frame S' has velocity v in the x direction (Which mean the length of the stick is only changed in the x direction)
So the angle in the S frame is..
Cos(θ) = (Cos(θ') + (v/c))/(1 + Cos(θ')*(v/c))
θ = Cos-1((Cos(θ') + (v/c))/(1 + Cos(θ')*(v/c)))
then
Lp = proper length = length in S frame
Lp = ɣL
lCos(θ') = The length of the stick in the x-direction
Lp = ɣlCos(θ')
Then the length of the stick in S = Lp/Cos(θ)
(b) Now we consider a particle moving with a velocity u' in frame S' at an angle θ' to the x' axis. Find the angle θ in frame S.
To do this I transformed the x and y components to the S frame then used tan(θ) = uy/ux
u'y=u'Sin(θ')
u'x=u'Cos(θ')
Then the transforms
ux = (u'x + v)/(1 + u'xv/c2)
and
uy = (u'y)/(ɣ(1 + u'yv/c2))
then..
tan(θ) = uy/ux
θ = tan-1(uy/ux)
Again does this look right? I'm not sure if I'm trying to over complicate things...
That should work, but even simpler is to consider the x & y components of the stick's length and compute how tanθ would transform.
then
Lp = ɣL
Lp = ɣlCos(θ')
Not sure what you did here. For one thing, only the x-dimension contracts. How does that affect the total length of the stick? (Again, consider the x & y components of the stick's length.) Also, presumably the stick is moving in the S' frame, so its length in that frame is its proper length.
u'y=u'Sin(θ')
u'x=u'Cos(θ')
OK.
Then the transforms
and
Double check that second transform.
then..
tan(θ) = uy/ux
θ = tan-1(uy/ux)
That should work.
then
Lp = ɣL
Lp = ɣlCos(θ')
Ahhhh always confuse the proper length... So the proper length is the length as measured by an observer at rest with the object, so Lp is the length in S'
So If the stick makes an angle θ' with the x' axis in the S' frame then its x component of it's length is lcos(θ') = Lpx
ɣ=(1 - v2/c2)-1/2
so in the S frame this length becomes Lpx
So the length of the stick in the S frame is (Lpx/ɣ)/Cos(θ)
Where θ is the angle the sticks makes with the x-axis in the S frame.
uy = (u'y)/(ɣ(1 + u'yv/c2)) uy = (u'y)/(ɣ(1 + u'xv/c2))
fixed!
Thanks for all the help!
ɣ=(1 - v2/c2)-1/2
OK.
But generally you'd want to express the answer in terms of the original S' variables, something like L = Lp*f(θ', v). (At least that's what I would expect if I asked for the length measured in the S frame.)
Yes I agree, was just trying to save writing it all out. If i knew how to do the fancy code I would ;)
Thanks Doc Al, always so helpful!
hey doc how did you ge thte angle in
It's a variant of the aberration formula. One way to derive it is to imagine a beam of light parallel to the stick, then use the addition of velocities formula to compute the horizontal component of the light velocity in the S frame. (The horizontal component is c*Cosθ)
  • · Replies 24 ·
