Kirchhoff's Current Law and Solving for Unknown Currents
  • Thread starter Thread starter jayjay112
    Current Law
The discussion revolves around applying Kirchhoff's laws to solve for unknown currents in a circuit. Participants are analyzing two proposed solutions based on Ohm's Law and Kirchhoff's Voltage Law (KVL).
  • Mixed
  • Participants explore the validity of two different solutions for calculating currents in a circuit, questioning the application of Ohm's Law without prior knowledge of voltages or currents. There is also discussion about setting up equations based on KVL and the implications of negative current results.
Some participants have provided guidance on the necessity of using simultaneous equations to find the unknowns, while others have pointed out potential errors in the initial assumptions. Multiple interpretations of the circuit's behavior are being explored, particularly regarding the application of Kirchhoff's laws.
There is an emphasis on the constraints of not using Ohm's Law prematurely, as well as the need to confirm solutions by ensuring that voltages and currents satisfy Kirchhoff's laws. The original poster expresses uncertainty about checking their answers through simultaneous equations.
jayjay112
Please see question at http://www.flickr.com/photos/38702264@N06/3556612295/sizes/o/
Which one of these solutions is correct?
1) V / R = I
6 / 1.5 = 4
i1 = 4a
3 / 2 = 1.5
i2 = 1.5a
i1 + i2 = i3
i3 = 5.5 amps
2)V / R = I
6 / 11.5 = 0.5217
i1 = 0.5217a
3 / 12 = 0.25
i2 = 0.25a
i1 + i2 = i3
i3 = 0.7717amps
Thanks for the help
definitely not the first, as the voltage across the 1.5 ohm resistor isn't 6 volts.
and the second one doesn't take into account that both currents flow through R3.
i could be wrong, but i think you have to consider it like this:
kirchoff said the vectorial sum of the voltages in a loop is 0.
but the voltage across the ten ohm resistor is the sum of both currents. ie, 10xI3. this can be written as 10(I1 + I2)
so for your first loop, I1,
6 - 1.5(I1) - 10(I1 + I2) = 0
do that for the second loop I2, and you'll get 2 equations, 2 unknowns.
Can anyone confirm this??
Thanks
Easiest way to confirm a solution is check that the answers work. Solve two equations for two unknowns. Using those answers, do the voltages around very loop add up to zero as required, and do currents at every node add up to zero as required? If so, you have checked your math.
I get an interesting result: I2 comes out negative, which is okay -- that's the way the math informs us that it flows in the direction opposite to the assumed arrow. So conventional current is flowing into the positive terminal of the 3 V voltage source.
Thats the problem i don't know how to check the answers by using two equations,
can anyone just tell me if either solution is correct or if they are both wrong?
Thanks
Both wrong.
You started out using Ohm's Law right away, which isn't allowed here.
If you know a resistor's current, Ohm's Law will tell you its voltage.
If you know a resistor's voltage, Ohm's Law will tell you its current.
But we have no way in the beginning to know either one, so we can't use Ohm's Law to find the other.
There is no other way except the simultaneous solution of two equations.
Using a positive term wherever a voltage source produces a "voltage rise",
and a negative term wherever a resistor produces a "voltage drop" ...
Sum of voltages around the first loop = 0.
6 - 1.5 I1 - 10 (I1+I2) = 0
Sum of voltages around the second loop = 0
3 - 2 I2 - 10 (I1+I2) = 0
Observation - I now have two equations and two unknowns. The number of equations is greater than or equal to the number of unknowns. That tells me that a solution is possible.
Then I personally use Cramer's Rule to solve them, but it's not the only way.
The other method is to substitute one equation into the other one.
Getting rid of the parentheses (the distributive property of algebra):
6 - 1.5 I1 -10 I1 -10 I2 = 0
3 - 2 I2 - 10 I1 - 10 I2 = 0
Putting them into the general form "a I1 + b I2 = c":
11.5 I1 + 10 I2 = 6
10 I1 + 12 I2 = 3
Now it's in the form to use Cramer's Rule immediately.
Do you know how solve the rest of it?
By the way, about the phrase you typed as the header of the forum thread, I'm using Kirchhoff's voltage law here to write my two equations. I'm not using Kirchhoff's current law to write my two equations.
you are using KCL when you define I3 = I1 + I2. but that's as far as it can go to my knowledge...
the rest is KVL
  • · Replies 18 ·
  • · Replies 31 ·
