Solving for the Derivative of a Square Root Function
  • Thread starter Thread starter Dude487
    Derivative
The discussion focuses on solving the derivative of the function f(x) = √((x - 2)/(x² + 1)) using the limit definition of the derivative. The correct formulation of the limit is f'(x) = lim (h → 0) [f(x + h) - f(x)]/h. Participants emphasize the importance of proper notation and parentheses for clarity, and provide guidance on manipulating the expression to find the derivative, including the necessity of obtaining a common denominator and rationalizing the expression.
  • Understanding of limits and derivatives in calculus
  • Familiarity with the limit definition of a derivative
  • Knowledge of square root functions and their properties
  • Basic algebraic manipulation skills, including rationalizing expressions
  • Study the limit definition of a derivative in detail
  • Learn how to rationalize expressions involving square roots
  • Practice solving derivatives of functions with square roots
  • Explore LaTeX formatting for mathematical expressions to improve clarity in communication
Students studying calculus, mathematics educators, and anyone looking to improve their understanding of derivatives involving square root functions.
Dude487
derivative problem...
f(x)=x-2/x^2+1 Square root
f(x)=lim f(x-h) - f(x)/h
h>0
f(x)= lim x+h-2/(x+h)^2+1 Square root - x-2/x^2+1 Square root
h>0 /h
I do have the answer... 2x+1/(x^2+1)^3/2
I know the first step would be to cross multiply the ones in the 3rd part. I get lost after that
man, I hope all that's understandable. hopefully someone can teach me how to do square roots and other stuff
just in case, the square roots go in x^2+1, (x+h)^2+1, and x^2+1 which are all denominators. and the h divides everything in the third part
This is so ambiguous I can't tell what the function is. You absolutely need parentheses here. Also, exactly what expression is inside the radical?
I'll take a wild stab at what I think you might mean:
[tex]f(x) = \sqrt{\frac{x -2}{x^2 + 1}}[/tex]
It's a safe bet that you don't know LaTeX scripting, so function formula I wrote above should be written something like this so that people can understand what you're trying to do.
f(x) = sqrt[(x - 2)/(x^2 + 1)]
h>0
The expression in the limit should be written as [f(x + h) - f(x)]/h
h>0 /h
Hallelujah, do I see a pair of parentheses? It would be better with another pair around the 2x + 1 part.
Cross multiply? Why would you do that?
This is a fairly tricky problem if you have to do it by using the definition of the derivative. If you are permitted to use some other technique, I would recommend doing it that way.
Here's to get you started:
[tex]f'(x) = \lim_{h \rightarrow 0} 1/h [f(x + h) - f(x)]<br /> = \lim_{h \rightarrow 0} 1/h [ \sqrt{\frac{x + h - 2}{(x + h)^2 + 1}} - \sqrt{\frac{x -2}{x^2 + 1}}]<br /> = \lim_{h \rightarrow 0} 1/h [ \frac{\sqrt{x + h - 2}}{\sqrt{(x + h)^2 + 1}} - \frac{\sqrt{x - 2}}{\sqrt{x^2 + 1}}][/tex]
Now it starts to get really ugly. You'll have to get a common denominator, and then you'll need to multiply the whole expression inside the brackets by 1, in the form of the sum of two radicals over itself. Then you can multiply by 1/h, and finally take the limit as h approaches zero.
  • · Replies 105 ·
13K
