| Thread Closed |
Using static friction to find tension |
Share Thread | Thread Tools |
| May29-09, 06:15 PM | #1 |
I am having a lot of problems with the tension/force questions on my homework. Here is the last question I don't understand in my homework set:
The drawing shows a circus clown who weighs 860 N. The coefficient of static friction between the clown's feet and the ground is 0.41. He pulls vertically downward on a rope that passes around three pulleys and is tied around his feet. What is the minimum pulling force that the clown must exert to yank his feet out from under himself? http://www.webassign.net/CJ/04_58.gif I know that the clown is in equilibrium when he is not moving and if he yanks his feet off the floor. Using the F=ma equation, I figured he would move in the y-direction. therefore F=ma=-(his weight)+(friction)=-860N+(860*0.41)=507.4N. Is that correct? Is it right to say that friction is felt in the y direction in this case because the clown is just standing on the floor? Does F(normal force) play a role in this problem? |
| May29-09, 06:24 PM | #2 |
If the clown pulls on the rope with a force F, what is the tension in the rope? What is the vertical force exerted by the rope on the clown? What is the normal force on the ground due to the clown? What is the horizontal force exerted by the rope on his feet?
| Thread Closed |
| Tags |
| free body diagram, static friction, tension |
| Thread Tools | |
Similar Threads for: Using static friction to find tension
| How to find Static Friction | Introductory Physics Homework | 1 | ||
| Trying to find static friction... | Introductory Physics Homework | 5 | ||
| Find the coefficient of static friction...help? | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Confused - How do I find the static and kinetic friction coefficient? | Introductory Physics Homework | 2 | ||
| Find max. speed with Static Friction | Introductory Physics Homework | 3 | ||
