Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image 2 Questions Share It Thread Tools Search this Thread image
Old May31-09, 03:57 PM                  #1
Matthollyw00d
Matthollyw00d is Offline:
2 Questions
First Question:
Let Nn be the integer whose decimal expansion consists of n consecutive ones. For example, N2=11 and N7=1,111,111. Show that Nn|Nm iff n|m.
Second Question:
If (a,c)=1, prove that (a,bc)=(a,b).
On the second question I can see that it is true because a and c are relatively prime, I realize that ax1+bx2=1, but I'm having difficulty expressing it in a proof satisfactory way. I think I'm just over looking a fact somewhere in my text.
As for the first one, I'm not very certain as to where at all to start, so any and all help here would be appreciated.
Note that I'm not really wanting the full proof of either, more or less just a few helpful pointers or some key facts that are needed that I'm missing; something to get me started so I can get a better attempt at it.
If anything is unclear, I'll be happy to restate it in a more satisfactory format if possible.
Thanks all.
Thanks all.
Old May31-09, 04:58 PM                  #2
tiny-tim
tiny-tim's Avatar
Homework Helper 2008
tiny-tim is Online:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Hi Matthollyw00d!
You're making this far too complicated …
Originally Posted by Matthollyw00d View Post
First Question:
Second Question:
For the first one, just divide … what is the remainder?
For the second, write a = np, b = nq, bc = nqc …
Old May31-09, 09:25 PM                  #3
Matthollyw00d
Re: 2 Questions
Would this be sufficient for the first one:
Assume Nn|Nm, then (t)Nn=Nm, t≥1. For all m,n≥1, there exists q,r such that m=qn + r, 0≤r<n.
Next assume m does not divide n, therefore 1≤r<n.
Thus Nm=Nqn+r=10r(s)Nn+Nr
Then, (t)Nn=Nqn+r=10r(s)Nn+Nr
Thus, Nr=Nn(t-s10r)=Nn(d), d≥1, which implies r≥n, which contradicts our hypothesis of r<n.
Thus Nn|Nm iff n|m.
Old Jun2-09, 05:07 PM                  #4
ramsey2879
ramsey2879 is Offline:
Re: 2 Questions
Thus Nn|Nm iff n|m.
If you work out a couple of divisions as a grade school student is taught a simpler proof should be apparent. First try LaTeX Code: /N_6/N_2 to get 010101. Then Try LaTeX Code: N_8/N_4 to get 00010001. Now what would the result of LaTeX Code: N_20/N_5 be?
Old Jun2-09, 11:08 PM                  #5
Matthollyw00d
Re: 2 Questions
Originally Posted by ramsey2879 View Post
If you work out a couple of divisions as a grade school student is taught a simpler proof should be apparent. First try LaTeX Code: /N_6/N_2 to get 010101. Then Try LaTeX Code: N_8/N_4 to get 00010001. Now what would the result of LaTeX Code: N_2_0/N_5 be?
00001000010000100001
But I'm not seeing a proof that is simpler than what I did unfortunately. =/
Old Jun5-09, 12:06 PM       Last edited by ramsey2879; Jun5-09 at 12:16 PM.. Reason: mod operator            #6
ramsey2879
Re: 2 Questions
Assume 0 < r < n
LaTeX Code: m = tn + r
LaTeX Code: N_{m} = N_{m} - (10^{(t-1)*n + r})*N_{n} \\mod N_n
LaTeX Code: N_{m} = N_{m-n} \\mod N_{n}
LaTeX Code: N_{m} = N_{m-n} - (10^{t-2}*n + r})*N_{n} \\mod N_n
LaTeX Code: 0 = N_{m-2n} \\mod N_{n}
LaTeX Code: 0 = N_{m - tn} \\mod N_n
LaTeX Code: 0 = N_{r} \\mod N_n
LaTeX Code:  r = 0
Old Jun5-09, 04:04 PM                  #7
Matthollyw00d
Re: 2 Questions
That would be why I didn't see it, I've yet to learn Modular Arithmetic.
Old Jun6-09, 04:45 PM                  #8
ramsey2879
Re: 2 Questions
Assume 0 < r < n
LaTeX Code:  r = 0
redoing this
If LaTeX Code: N_{n}|N_{m} then LaTeX Code: N_{n} also divides:
LaTeX Code: N_{m} - (10^{(t-1)*n + r})*N_{n}  which has the same remainder i.e., zero But that is LaTeX Code:   N_{m-n}  since you just removed the first n LaTeX Code: 1 's. This is simply going through the longhand division process as the divisor multiplied by LaTeX Code: 10 to the appropiiate power removes the n most righthand LaTeX Code: 1 's. When doing longhand division in this manner you are not changing the ultimate remainder so we can say that the new term LaTeX Code: N_{m-n} = N_{m} \\mod N_n (i.e. they have the same remainder if divided by LaTeX Code: N_n ).
Likewise we continue the longhand division process by removing the next n most righthand LaTeX Code: 1 's and so on until we removed t*n LaTeX Code: 1 's. The resulting number comprises r LaTeX Code: 1 's and has the same remainder as the original number. So we say LaTeX Code: N_{m} = N_{r} \\mod N_n iff LaTeX Code: m = r \\mod n . Since n|m, r = zero is the only possible r less than n.
image image
Reply
Thread Tools
Similar Threads for: 2 Questions
Thread Thread Starter Forum Replies Last Post
Can u plz help me with this questions ??? eman.kh General Math 2 Nov4-07 09:15 PM
Questions byerly100 Advanced Physics 3 Oct3-06 02:38 PM
two questions...help please smileyjen523 Introductory Physics 4 Oct10-05 10:48 AM
Three questions. mprm86 General Physics 3 Mar31-05 12:33 AM
Two EPR questions Blake Winter General Physics 90 Nov25-04 04:36 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
