Thread Closed
more rust in less salt??
Share Thread Thread Tools
Jun2-09, 01:56 AM   #1
As part of my chemistry experiments on corrosion, I am noticing that the steel nails are rusting more in solutions of 3.5g/L salt, than 35g/L salt. What could be some reasons to explain this??
I would have thought that the 35g/L solutions would have lead to more rust, not less.
Perhaps there is another reaction going on.
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Attacking MRSA with metals from antibacterial clays
>> Femtosecond 'snapshots' reveal a dramatic bond tightening in photo-excited gold complexes
>> Beautiful 'flowers' self-assemble in a beaker
Jun2-09, 02:56 AM   #2
Admin
No idea, but I would start checking oxygen solubility and difusion coefficient in the concentrated NaCl solution.
Jun2-09, 04:51 AM   #3
Recognitions:
Reminds me that I really should brush up on my electrochemistry. :(
I'm guessing that corrosion is being inhibited due to to reduced solubility of the resultant ions, due to the high ionic strength of the solution. Although Borek's suggestions are good too.
Jun2-09, 06:43 AM   #4
Admin
Quote by alxm View Post
That makes me think... I would expect quite the opposite, increase of the solubility. Fe3+ is easily complexed by the Cl-. But a lot depends on the solution pH, as Cl- can be too weak complexing agent to prevent hydrolysis and Fe(OH)3 precipitation.
Could be nails are corroding more, just there is less rust visible.
Jun2-09, 07:01 AM   #5
In the low saline solution, there is both more visible surface rust on the nails, as well as flaked off rust. The high saline solutions have almost no surface rust, but a little less flaked off rust than the low saline solutions.
Jun2-09, 08:21 AM   #6
Recognitions:
Quote by Borek View Post
Yeah, no you're probably right. Corrosion should normally increase with ionic strength.
The oxygen idea seems plausible though - it appears oxygen solubility does decrease with salinity. Corrosion in water is likely oxygen-limited (unlike in air).
Thread Closed
Thread Tools
Similar Threads for: more rust in less salt??
Thread Forum Replies
Iodized salt vs. pure kosher salt General Discussion 13
Rust and pathogens Biology 14
Can u rust a magnet using vinegar and salt water in a reasonable time? Materials & Chemical Engineering 1
Can Heat Alone Cause Rust? Materials & Chemical Engineering 4
Rust Filtration? Chemistry 7
