| Thread Closed |
Forward resistance of the Base -Emmiter Junction? |
Share Thread |
| Jun4-09, 02:38 AM | #1 |
Forward resistance of the Base -Emitter Junction showed a value of 12ohms when it was measured by (x1) resistance scale of an analogue multimeter .And it showed 70ohms when it was measured using (x 10) scale factor .The variation in the two readings occurs due to 1.the presence of Base Collector junction 2.thin base region 3.Different bias potentials applied by the meter 4.An error in the multimeter 2. Relevant equations 3. The attempt at a solution This is an MCQ question and i don't have any-works to show >But i personally think answer should be C.Can anyone help me !!!!!!!!! |
| Jun4-09, 07:03 AM | #2 |
no answers for 5 hours !!!!!!!!!!!
| Jun4-09, 11:04 AM | #3 |
Mentor
| Jun4-09, 06:09 PM | #4 |
The transistor has a dynamic emitter resistance, Re, which depends on the collector current. Collector current is a function of...
| Jun15-09, 07:46 PM | #5 |
Recognitions:
The base emitter junction of a BJT behaves just like any other diode and its resistance varies with voltage. The curve of this function is very non linear.
So, yes, I think your answer is correct. 3.Different bias potentials applied by the meter |
| Thread Closed |
| Tags |
| bjt |
Similar discussions for: Forward resistance of the Base -Emmiter Junction?
| Suggestion Spring Forward | Forum Feedback & Announcements | 2 | ||
| Base N to Base N Conversion | Linear & Abstract Algebra | 1 | ||
| Acid-Base neutralization w/ more than 1 base. | Chemistry | 6 | ||
| forward force? | General Physics | 2 | ||
