Exploring the Meaning of Positive and Negative Energy in the Klein Gordon Field
The discussion revolves around the interpretation of positive and negative energy in the context of the Klein-Gordon field, focusing on the roles of creation and annihilation operators in quantum field theory (QFT). Participants explore both mathematical formulations and physical interpretations, addressing concepts relevant to theory and conceptual understanding.
  • Some participants discuss the Hamiltonian of the Klein-Gordon field and the implications of positive and negative energy components in quantum mechanics.
  • There are explanations of how the creation operator is associated with negative energy and the annihilation operator with positive energy, though the physical meaning of these associations is questioned.
  • One participant suggests that creation and annihilation operators do not have specific physical meanings but are convenient symbols for writing observables.
  • Another participant emphasizes that quantum fields are building blocks for interactions and do not have a direct physical interpretation.
  • There is a query about whether the field operator is an operator or an operator-valued distribution, with some suggesting the latter is appropriate.
  • Some participants mention the transition from non-relativistic quantum mechanics to relativistic quantum field theory, highlighting the introduction of antiparticle states and the complexity of the energy spectrum.
  • One participant reflects on their understanding of Fock states and the representation of identical particles in quantum mechanics, indicating a learning process.
Participants express a range of views on the physical interpretation of creation and annihilation operators, with no consensus reached on their meanings or the implications of the Klein-Gordon field's energy components. The discussion remains unresolved regarding the deeper physical significance of these concepts in QFT.
Some limitations in understanding may stem from the complexity of transitioning from non-relativistic to relativistic frameworks, as well as the abstract nature of quantum fields and operators. The discussion reflects various interpretations and assumptions that are not universally agreed upon.
maverick280857
Hi everyone
The Hamiltonian of the Klein Gordon field can be written as
[tex]H = \frac{1}{2}\int d^{3}E_p \left[a^{\dagger}(p)a(p) + a(p)a^{\dagger}(p)\right][/tex]
and we have
[tex][H,a(p')] = -E_{p'}a(p')[/tex]
[tex][H,a(p')] = +E_{p'}a^{\dagger}(p')[/tex]
The book I'm reading states that
What was the positive energy component of the classical field now annihilates the quantum, and the negative energy component now creates the quantum.
What does this mean?
Thanks.
[tex][H,a^{\dagger}(p')] = +E_{p'}a^{\dagger}(p')[/tex]
[tex]|p'>=a^{\dagger}(p')|0>[/tex]
has energy [tex]E_{p'}[/tex] because:
[tex]H|p'>=Ha^{\dagger}(p')|0>=[H,a^{\dagger}(p')]|0>+a^{\dagger}(p')H|0>[/tex]
The 2nd term is zero because the vacuum |0> has no energy so is a zero eigenvalue of H. The 2nd term is equal to [tex]E_{p'}|p'>[/tex]
and hence the state |p'> has that energy, and was created from the vacuum |0> by the creation operator 'a dagger (p')'.
The quantum field looks like
[tex]\phi(x) = \int d^3p a^{\dag}(p) e^{ipx -iE(p)t} + a(p) e^{-ipx +iE(p)t}[/tex]
So, creation operator is associated with "negative" energy exp(-iEt) and annihilation operator is associated with "positive" energy exp(iEt).
Thanks meopemuk, this is a cool way of looking at it.
Thanks RedX, this also clarifies my doubt about the operators.
Now, a question to both of you: what does creation and annihilation really mean here, physically? I understand how these operators work mathematically and how this is a generalization of the nonrelativistic simple harmonic oscillator in QM. But what I want to understand more deeply is their physical meaning, in QFT.
Now let's say I have a scalar field [itex]\phi[/itex] in a region, described by the expression meopemuk has given.
(a) What is the (physical) interpretation of the linear superposition of the two exponentials, suitably weighted by the creation and annihilation operators, in the context of QFT?
(b) Is [itex]\phi(x)[/itex] so defined, an operator or an operator valued distribution?
Hi maverick,
I'll give you my personal opinion, which is not necessarily in accord with most textbooks.
Creation/annihilation operators do not have any specific physical meaning. They are just convenient symbols for compact writing of physically relevant operators of observables (see e.g. the total momentum and energy discussed in a parallel thread).
Quantum fields do not have physical interpretation either. They are just convenient building blocks for relativistically invariant and cluster separable interactions in the Hamiltonian. This point of view was expressed most forcefully in S. Weinberg "The quantum theory of fields", vol. 1.
This is an operator function depending on 4 real parameters. So, "operator valued distribution" is an appropriate name.
Hi everyone
The book I'm reading states that...
Thanks.
It is easy to understand if you know how to describe a system of identical particles in the non relativistic QM. Learn first that. You will see how one goes from the (anti) symmetrized product of the usual wave functions to the representation in population numbers.
The difference between non relativistic and relativistic QM of many particles is in larger number of possible states: in the latter case there are also the states with negative frequency = the antiparticle states. The rest is quite similar to the non-relativistic case. You will find all answers there.
Bob_for_short.
Thank you.
You can view the creation and annihilation operators as operators that creaet/destroy the energyquanta of the system. All states are build up from the vacuum using the creation operators.
In the non-interacting case the spectrum is continous. But remember for instance the hydrogen atom: in that case there is a discrete spectrum of energy levels (the bound states). This is in essence the "quantum" in quantum theory: systems tend to develop a smallest energy quanta.
As for the field operator: in non-relativistic quantum mechanics the field operator is in fact nothing but the wavefunction. It has a clear meaning, since it's absolute square stands for the probability distribution of the particle at hand. In relativistic QFT this picture breaks down, and the field operator can strictly no longer be viewed as such a distribution. It should be viewed as an operator which contains all the information possibly present in the physical state. But only by acting on the state with this field operator can we extract this information. By itself the field operator is "just" a mathematical construct - it has no physical meaning, yet.
I did that, re-read the section on Fock states and went back to QFT. I think I have a better understanding of it now. Thank you :smile:
  • · Replies 24 ·
  • · Replies 17 ·
  • · Replies 113 ·
14K
