Thread Closed
Confused about the difference between impulse momentum and kinetic energy
Share Thread Thread Tools
Jun8-09, 10:17 AM   #1
1 mass M1 of 1 kg moves frictionless at V1 1 meter per second to the right. It fuses with mass M2 of 2 kg and together they keep moving frictionless to the right. What is the speed V2 of the fused objects?
2. Relevant equations
Impulse mass * Velocity
Kinetic energy mass * velocity^2
3. The attempt at a solution
Conservation of energy 1/2*M1*V1*V1 = 1/2 [Joule] = 1/2*(M1+M2)*V2*V2
V2=SQRT (1/3) [m/s]
Conservation of momentum M1*V1 = (M1+M2)*V2
V2=1/3 [m/s]
My confusion is.
When and why should I conserve momentum and when and why should I conserve energy?
I think I can imagine what is energy of a moving object, however I think that somehow I cannot imagine what is momentum.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun8-09, 10:28 AM   #2
Mentor
Quote by quirck View Post
My confusion is.
Remember that momentum is conserved in any collision, but kinetic energy is only conserved in some collisions. When the masses bounce apart and energy is conserved, that's called an elastic collision; when they stick together, that's called an inelastic collision (and energy is not conserved).
In this problem, energy is not conserved.
Jun8-09, 12:51 PM   #3
[q]In this problem, energy is not conserved.[/q]
Thank you for the quick reply. Very kind.
I understand you want to stay simple here and this rule of thumb is applicable here, however I want to get a deep understanding of this. Most of all I want to try to get a grasp on what is momentum. Like understanding it so much that even my stomach also understands.
We understand of course that also energy of a closed system is always conserved. So the energy must have gone somewhere. I suspect some kinetic energy was transformed from kinetic to heat or deformation. That would be an answer to the question where the energy would have gone.
But then why is momentum conserved? For me it is still is a rule that is just applied and seems to work in the real world. I have a vivid imagination about how energy is conserved. I just like to have the same vivid imagination about momentum conservation.
Do you have any idea how to explain?
Jun8-09, 01:14 PM   #4
Mentor
Good!
If you understand that the force on an object tells you the rate of change of its momentum, and you understand that whenever two objects collide they exert equal and opposite forces on each other (as per Newton's 3rd law), then perhaps the fact that total momentum is always conserved in a collision will make more sense.
Read this tutorial: Momentum and Its Conservation
Thread Closed
Thread Tools
Similar Threads for: Confused about the difference between impulse momentum and kinetic energy
Thread Forum Replies
Understanding derivation of kinetic energy from impulse? Classical Physics 3
finding the coefficient of kinetic friction using impulse/momentum Introductory Physics Homework 8
Momentum and kinetic energy through potential difference Advanced Physics Homework 1
potential difference and Kinetic energy Introductory Physics Homework 1
