Thread Closed
Modern Algebra - units and zero divisors
Share Thread Thread Tools
Jun8-09, 10:49 AM   #1
This is my first assignment in my Modern (Abstract) Algebra class, just to give an idea where I am with tools that I can use.
Describe all units and zero divisors in Z[i]
2. Relevant equations
3. The attempt at a solution
I already know the answers are units = 1, -1, i, -i
and zero divisors: none
I know I can get 1 and -1 by setting them up as multiplicative inverses:
1x = 1(mod i) and -1x = 1(mod i) where x is 1 and i-1 respectively.
But I am not sure how to go about getting i and -i, nor do I agree with them based on my understanding and previously worked problems. One question I have is why the book writes Z[i] with brackets when it never uses brackets when the mod is an actual number or when it is the variable n. Am I missing something special with that notation?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun8-09, 11:12 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
It doesn't mean (mod i). It means the integers extended by i. I.e. all numbers of the form n+m*i where n and m are integers.
Jun8-09, 01:32 PM   #3
Quote by Dick View Post
Thank you for that. Your explanation led me back to the previous section where they covered a+bi Gaussian integers and the very last sentence of the section made the comment that Gaussian integers were represented by Z[i].
I already proved in the previous section that a+bi = i(b-ai) and that b-ai is a Gaussian integer, so all Gaussian integers (Z[i]) are multiples of i.
I can also say that a+bi = -i(-b+ai) and -b + ai is a Gaussian integer.
and a+bi = 1(a+bi) where a+bi is a Gaussian integer
and a+bi = -1(-a-bi) where -a-bi is a Gaussian integer
so 1, -1, i and -i are all units.
I believe the above is correct, but I still feel like I am missing a main point here. For instance, to be a zero divisor, you multiply it by a nonzero number and get zero. I am not sure how to think about that in terms of a Gaussian integer.
Am I supposed to think of it in terms of "for any a and b, a+bi multiplied by any number can not be zero"? And in this case, should I be thinking in terms of the point (0,0) or the number 0? I feel like it is on the tip of my tongue, so to speak, but I just can not quite grasp it.
Jun8-09, 01:42 PM   #4
Recognitions:
A zero divisor is a case where you have Gaussian integers such (a+bi)*(c+di)=0. A unit is a Gaussian integer such that 1/(a+bi) is a Gaussian integer. To find out whether there are such things, think about multiplying by compex conjugates, or maybe what you might know about multiplication and division of complex numbers.
Jun8-09, 02:56 PM   #5
okay, the concepts here are being stubborn about not sinking in. By multiplying complex conjugates, I believe you mean (a+bi)(a-bi)= [tex]a^{2}-i^{2}b^{2}=a^{2}+b^{2}[/tex]
So 1/(a+bi) * (a-bi)/(a-bi) = (a-bi)/([tex]a^{2}+b^{2}[/tex])
so then (a-bi)/([tex]a^{2}+b^{2}[/tex]) = a/([tex]a^{2}+b^{2}[/tex])-(b/([tex]a^{2}+b^{2}[/tex]))i which is a guassian integer. Am I on the right track with where you are pointing me?
Thanks so much for you assistance, I feel like I am close!
Jun8-09, 02:59 PM   #6
by the way, I am wondering why this does not work for an explanation?
a+bi = i(b-ai) and b-ai is another Gaussian integer, so any a+bi is a multiple of i.
a+bi = -i(-b+ai) and –b+ai is another Gaussian integer, so any a+bi is a multiple of -i.
a+bi = 1(a+bi), so any a+bi is a multiple of 1.
a+bi = -1(-a-bi) and –a-bi is another Gaussian integer, so any a+bi is a multiple of -1.
Therefore, i, -i, 1, and -1 are all units of Z[i]
Is that just completely off the wall?
Jun8-09, 03:18 PM   #7
Recognitions:
Quote by Proggy99 View Post
Sure. Now ask yourself how a/(a^2+b^2) and b/(a^2+b^2) can be an integer if a and b are integers. Hint: if |a|>1 then a^2>|a|. Showing for example that any Gaussian integer is a multiple of e.g. i, does show i is a unit, but mostly because then 1 is a multiple of i, and so i is invertible. But it seems simpler just to say i*(-i)=1. That argument shows you that 1,-1,i and -i are units. But it doesn't prove they are the only units.
Jun8-09, 03:50 PM   #8
hmmmm, so a/(a^2+b^2) can only be an integer if a^2+b^2 is a, 1 or -1, but b/(a^2+b^2), implies that a^2+b^2 is b, 1 or -1.
Therefore, a^2+b^2 must equal 1 or -1. For that to be true, then either a^2=1 and b^2=0 or a^2=0 and b^2=1.
Then a=1 or -1 and b=0 or b= 1 or -1 and a =0.
Plugging those in gives a/(a^2+b^2) = (1+0i)/1 or (-1+0i)/1 = 1 or -1
and a/(a^2+b^2) = (0+1i)/1 or (0-1i)/1 = i or -i
Is that it?
I will have to look at any response and how to show there are no zero divisors later on tonight. Thanks!
Jun8-09, 03:56 PM   #9
Recognitions:
Your reasoning is a little sloppy. |a|<=(a^2+b^2) with equality holding only if |a|<=1. Right? Similarly, |b|<=1. Can a and b both be nonzero?
Thread Closed
Thread Tools
Similar Threads for: Modern Algebra - units and zero divisors
Thread Forum Replies
Modern Algebra - What is it? Calculus & Beyond Homework 1
Introduction to Modern Algebra. Science Textbook Discussion 0
Applications of modern algebra Academic Guidance 42
Modern Algebra Academic Guidance 4
Modern Algebra? General Math 6
