| Thread Closed |
Sketching level curves of f(x,y) |
Share Thread | Thread Tools |
| Jun12-09, 06:55 AM | #1 |
Sketch the level curve of the surface [tex]z = \frac{x^2 - 2y + 6}{3x^2 + y}[/tex] belonging to height z = 1 indicating the points at which the curves cut the y−axis. 2. Relevant equations 3. The attempt at a solution I put [tex]1 = \frac{x^2 - 2y + 6}{3x^2 + y}[/tex] but then don't know how to proceed. The answer shows an inverted parabola at y = 2, but I don't know how to get that. |
| Jun12-09, 07:19 AM | #2 |
From
[tex] 1 = \frac{x^2 - 2y + 6}{3x^2 + y} [/tex] it follows that [tex] 3x^2 + y = x^2 - 2y + 6 [/tex] Can you cast this in the form y = f(x) ? |
| Jun12-09, 10:03 AM | #3 |
Do you mean like this...
[tex]3x^2 + y = x^2 - 2y + 6[/tex] [tex]3y = -2x^2 + 6[/tex] [tex]y = \frac{-2x^2 + 6}{3}[/tex] [tex]y = \frac{-2x^2}{3} + 2[/tex] ??? |
| Jun12-09, 10:11 AM | #4 |
Yes.
Now, that's a parabola, isn't it? It's of the general form y = ax^2 + bx + c with a = -2/3, b = 0, c = 2; you can see that it is inverted (like a mountain top) because a < 0. |
| Jun12-09, 11:04 PM | #5 |
Ok, that explanation helped, thankyou.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Sketching level curves of f(x,y)
| Sketching Curves | Calculus & Beyond Homework | 2 | ||
| Sketching level curves | Calculus | 7 | ||
| Sketching Level Curves | Calculus & Beyond Homework | 9 | ||
| sketching curves: intercepts, asymptotes, critical points...[answer check] | Calculus & Beyond Homework | 5 | ||
| [SOLVED] Sketching the Curves of a Function W/In an Interval - Simple (1st Year Calcu | Calculus & Beyond Homework | 3 | ||
