Projectile Motion w/ unknown initial velocity & uneven launch/landing points
The problem involves projectile motion, specifically analyzing the trajectory of a baseball thrown at an angle of 60 degrees. The baseball strikes a building 18 meters away and 6 meters higher than its launch point, with air resistance ignored.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss using kinematic equations to relate the horizontal and vertical motions of the projectile. There are attempts to manipulate these equations to find the initial velocity and address the conditions of the problem. Some participants question the complexity of the resulting equations and the approach taken.
There are various approaches being explored, with some participants suggesting substitutions and others expressing confusion about the resulting equations. Guidance has been offered regarding the use of specific kinematic equations, but no consensus has been reached on a single method.
Participants note potential issues with the interpretation of the problem and the setup of equations, as well as the challenge of managing the quadratic nature of the resulting calculations.
txaggiejs18
A baseball thrown at an angle of 60.0 above the horizontal strikes a building 18.0m away at a point 6.00m above the point from which it is thrown. Ignore air resistance.
A) Find the magnitude of the initial velocity of the baseball (the velocity with which the baseball is thrown).
B) Find the magnitude of the velocity of the baseball just before it strikes the building.
C) Find the direction of the velocity of the baseball just before it strikes the building.
known:
initial angle = 60o
x = 18, y = 6 @ point of impact
a = 9.8 m/s2
x = v0x*t
y = v0y*t + .5*a*t2
I began by manipulating the equations above to create an equation that solves for the magnitude of the velocity, v at x=18, y=6 :
18 = cos(60)*v*t
6 = sin(60)*v*t + .5*a*t2
t = 18/(cos(60)*v)
6 = sin(60)*v*(18/(cos(60)*v))+.5*-9.8*(18/(cos(60)*v))2
v = sqrt((.5*-9.8*182)/(6-(18*sin(60)/cos(60))))/cos(60)
And using this I found v to be 15.9, which is incorrect. I don't think the rest will be any problem if I can figure out v, but I can't find what I'm doing wrong for the life of me. Also, if there is a different approach I should be taking please tell me, thanks!
Try using the position kinematic equation y=-1/2gt^2+vsin(60)t+yo and set the final value (y)at six meters. And the equation x=-1/2gt^2+vcos(60)t+xo, since there is no acceleration in the x vector the equation becomes 18=vcos(60)t, therefore v=18/cos(60)t sub it into the y position equation. You get 6=-4.9t^2+(18*sin(60))/(cos(60)), or t=sqrt((18tan(60)-6)/4.9). Then sub the time back into the v=18/cos(60)t equation. V=9*sqrt((18tan(60)-6)/4.9)
Try using the position kinematic equation y=-1/2gt^2+vsin(60)t+yo and set the final value (y)at six meters. Solve for time the substitute the time into the velocity equation in the x direction, then just solve for average velocity.
Doesn't this lead to a quadratic equation with t? That's what I ended up with and it's getting messy and even harder to follow...unless I'm misunderstanding you?
Sorry about the first post I edited it, you were on the right track just use substitution
Ah, thank you...I just realized that I was entering 15.9 into the wrong blank on the submission form...I'm resisting the urge to slam my fist through my wall.
