Unraveling Tensor Notation: Extracting Equations
The discussion revolves around the extraction of individual equations from tensor notation, specifically focusing on a complex equation involving tensors and the Levi-Civita symbol. Participants explore the challenges of translating tensor notation into explicit equations, particularly in the context of Einstein summation and the implications of superscripts and subscripts.
  • One participant expresses difficulty in extracting individual equations from the tensor notation and seeks clarification on the method to do so.
  • Another participant confirms that the equation represents 9 equations and emphasizes that all subscripts and superscripts count in the summation process.
  • A participant suggests fixing specific indices to extract one of the equations and questions whether a referenced document provides examples.
  • One participant attempts to simplify the problem by relating it to linear algebra and discusses the outer product of vectors.
  • Another participant challenges the simplification of the Levi-Civita symbol's role, asserting that it is integral to the summation and must be considered in the extraction process.
  • There is a discussion about the nature of the tensors involved, with one participant noting that the tensors combine to form a matrix while another clarifies the complexity of their interactions in different coordinate systems.
Participants generally agree on the representation of the equations and the importance of considering all indices in the summation. However, there are competing views on the role of the Levi-Civita symbol and the method of extraction, indicating that the discussion remains unresolved.
Participants express uncertainty regarding the implications of superscripts and subscripts in the context of Einstein summation, as well as the method for extracting equations from the given tensor notation.
junglebeast
I can't seem to wrap my mind around it. I understand the concept of it, but I can't figure out how to translate that concept into actually extracting the individual equations from tensor notation.
For example,
[tex] a^i \: b^j \: c^k \: \epsilon_{jqs} \: \epsilon_{krt} \: \tau_i^{qr} = 0_{3 \times 3}[/tex]
note that [tex]a,b,c[/tex] are [tex]3 \times 1[/tex] and [tex]\tau[/tex] is [tex]3\times 3 \times 3[/tex].
This represents 9 equations. I understand how to calculate the value of the http://mathworld.wolfram.com/PermutationSymbol.html" , but this is complicated by having both superscripts and subscripts, and I'm also not sure if the subscripts of [tex]\epsilon[/tex] count in Einstein summation. My biggest problem is that I don't understand the "method" that can be used to extract the actual equations out of this!
If someone could show me how to extract just 1 of the equations that would help a lot
… this is complicated by having both superscripts and subscripts, and I'm also not sure if the subscripts of [tex]\epsilon[/tex] count in Einstein summation. My biggest problem is that I don't understand the "method" that can be used to extract the actual equations out of this!
Hi junglebeast! :smile:
(btw, you needn't say [tex]a,b,c[/tex] are [tex]3 \times 1[/tex] and [tex]\tau[/tex] is [tex]3\times 3 \times 3[/tex] … it's obvious from the number of indices :wink:)
Yes, it's 9 equations, for each of the 3 values of s and t.
And yes, all subscripts and superscripts count, even in deltas and epsilons.
Extracting one of the 9 equations simply involves fixing say s = 2, t = 3, and summing over all the rest … doesn't that .pdf (which I haven't looked at) give any examples?
Hi tim!
Let me start with something simpler...I'll try to show my process
[tex] a^i b^j = R^{ij}[/tex]
I understand how I can convert the above into linear algebra,
[tex] \mathbf{a} \mathbf{b} ^\mathsf{T} = \mathbf{R}[/tex]
...it's just the outer product. I could write this out elementwise as
[tex] \mathbf{R}(i,j) = a(i) b(j)[/tex]
(where parenthesis are used to indicate the indices)
Ok, so now I try to do this with 3 vectors. Written in tensor notation, it is
[tex] a^i b^j c^k = R^{ijk}[/tex]
If I'm not mistaken, this is a 3x3x3 cube which can be written out elementwise as
[tex] \mathbf{R}(i,j,k) = a(i) b(j) c(k)[/tex]
Now, [tex]\tau[/tex] is also a cube...and these somehow combine together to make a 3x3 matrix (ignoring the [tex]\epsilon[/tex] which just control the sign or cancellation).
To extract one of the equations it makes more sense for me to think about holding q and r constant. So let's say I choose q = r = 1. Ignoring the $\epsilon$ factors, I will try to sum over the rest...
[tex] \sum_i \sum_j \sum_k \sum_s \sum_t a(i) \: b(j) \: c(k) \: \tau(i,q,r) = 0[/tex]
Well that seems to contradict what I was doing earlier which did not have summations
No, you've lost me here. :confused:
epsilon doesn't "just control the sign or cancellation" … it's an integral part of the summation, and all three of its indices have to be summed over.
Yes, Rijk is a 3x3x3 cube, and so are Rijk and so on …
in Cartesian coordinates, the "cubes" have the same entries except that some entries are multiplied by minus-one (though in other coordinate systems, it's more complicated).
(and I haven't followed your final question)
  • · Replies 16 ·
