Thread Closed
Prism - emergent angle anomaly
Share Thread Thread Tools
Jun19-09, 05:30 AM   #1
A ray of monochromatic yellow light is incident in air on an
equilateral triangular glass prism. This ray is in the same plane as
the equilateral triangular cross section of the prism; the angle
between the ray and the prism face is 60°, and the refractive index
of the glass is 1.54 for this light.
Find the angle the emergent ray makes with the prism face at
which it emerges. Illustrate your answer with a diagram.
The given answer is 60 degrees. The problem appears straightforward but it appears impossible to get the required result with the given data. Please check my solution and comment...
2. Relevant equations
Snells law: n1*sin theta1 = n2 sin theta 2
3. The attempt at a solution
For angle of refraction of the incident light - from air into the prism:
sin r = sin 30/1.54, r = 18.94 degrees
The angle of incidence upon striking the internal glass surface = 60-18.94
Therefore the angle of refraction - from glass back into the air:
= asin(1.54 * sin(60-18.94))
The difficulty is that the inner sin function gives a value > 1
Have I done something wrong?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun19-09, 05:47 AM   #2
Recognitions:
Homework Helper Homework Help
60-18.94 = 41.06 is greater then the critical angle. Now draw the ray diagram and find the angle of incidence of the total internal reflected ray on the prism face.
Jun19-09, 10:32 AM   #3
Quite so... many thanks for your help!!!
Thread Closed
Tags
optics, prism, refraction, snell's law
Thread Tools
Similar Threads for: Prism - emergent angle anomaly
Thread Forum Replies
An Emergent God General Discussion 32
Critical Angle Prism Introductory Physics Homework 1
How does the angle at which a ray of light strikes a prism compare with the angle at Introductory Physics Homework 9
mathematical derivation for the minimum deviation angle for a prism Math & Science Software 5
